11.00 twin turbo g8
Pretty impressive, put 100 shot on it and if it hooks should run low 10's or maybe even break into the high 9's. Maybe spray it in 2nd instead of at wot which most systems are set up for. You know whats really impressive, the mph. My nova ran 9.70 at 138, he's running 11.00 at 130. Those turbos are really making some hp on the big end, only 7.5 lbs of boost.
Eric did a recent post on the G8 forum and its got about 10,000+ miles on it right now. That is really impressive. It will also run low 12's with 7lbs of boost and 11.00 with 14lbs. He's probably daily driving with 7lbs. and turns up the wick at the track. That in my opinion is the best bang for the buck and will still get decent mileage at 7lbs. It is the stock long block and tranny with stock converter.
