My quest for 11.3 Cam only
Rwhp is 398 from a dynojet. I suspect that the actual rwhp is closer to 420-425, but the A4, the 3600 stall, gears, and the sticky mickeys bring the number down some.
The mods to the engine are kooks 1 3/4, ported Fast, & MTI G1 cam (228/232 .588/.575 113), and a Volant cai. Still have stock TB & pulley.
I probably gained about 3-4 tenths from the gears; hard to tell because of different track conditions.
I've never run slicks, just drag radials (18psi), (30 psi in the rear bags).
1/8 was 7.18@95
With a 2800 stall and 275/45/17 nittos and stock gears I put down 436whp with a locked converter. That 3600 stall is probably why you got such a good 60 foot. I'm going to try for a high 1.5 to low 1.6 and I'd be happy with that. My best so far is 1.64.
You know what your shift mph/rpm settings are for the tranny with the 3.91s? I think unless I have a template it will be a pain to figure out.
Your mods sound like mine, but i have a ported TB and pulley.
I have the the shift points at 6200, but on the logs of the run the rpms go to 6500 and sometimes 6700 before it actually makes the shift. If you have HP Tuners I can email you a copy of the tune if you like.
PM sent with email. Thanks.
Just started this morning on the way to work.....car won't shift from 2-3 under full throttle. Just tried lowering the shift rpm and the shift mph. Neither worked. It's like it doesn't even try to shift to 3rd. I even tried manully shifting it to 3rd and it still bounced off the rev limiter. Does that every time now. This is my second stock tranny.
#32
Got the gears installed today. So far I really like them. Once they have some miles on them I'll floor the car and see if it shifts from 2-3 now. Shop put the original tune back in. Most think It's something I did with the tune....i don't think so but I hope that's it. I'm not real optimistic though.
#33
Any update if it was the tranny or the tune. (I looked around and didnt see a different thread on it)
