JBA Catless Mids Install 06 GTO
What tools did you guys need to install the JBA Catless Midpipes on an 06 GTO? I think the only problem I'm going to run into is hard to reach header bolts where the stock mid pipe connects to the exhaust manifold. It looks like they are in hard to reach areas. Any suggestions or unexpected problems you all ran into? Thanks!
Just make sure you have a 18 inch extension and one swivel socket and ratched. A wrench for the 02's It took about 20 mins total to install mine including jacking the car up and putting it on stands.
Thanks for the input! I think I got all the tools I'll need for this install. I'll just hope all the o2 sensors & nuts/bolts loosen up easily and i'll be fine. Thanks again!
