GTO Drag Racers with the M6 - Help me I s uck
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
2nd gear burnouts last longer and will get the tires hotter.
on my nittos last year i would launch at 3-3.5k ran 1.9's all the time and did cut a 1.8..
Nittos are sold now and gonna buy some Mickey Dr's.
If you are launching on street tires, I would launch at 1800 RPM and slip the clutch a bit. When my car was stock, I was running consistent 1.9x 60 fts and low 13 sec ETs without any problem.
what do you guys sugest for a procharged 04 on bfgs its my buddys car he is really bad out of the hole ??? he takes off at 1500rpm any higger and he fries the tires .need some help because im killing him with my 04 supercharged silverado ss. dont think im talkin ish because at about 120 he passes me up doin about 130 easly
Besides slicks, is there any other tips/tricks to getting a better 60ft? I launch at about 2k RPM and was getting 2.260ft's this weekend on my all season tires, I'll be using the drag radials this coming weekend though.
I had a 94mph trap speed in the 1/8th, so I know the car has the power, I just suck at launching![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
BIG *** BURNOUT !!!!!!
is it a M6?
pull into the burnout box (with the rear tires)
put the car in 2nd gear,
rev to 5K, dump the clutch, then put your left foot on the brake
hold it there
hold the revs at 4-5K rpm for about 5-8 seconds (2-4 seconds of really good smoke)
then let off the brake, keep your foot on the gas
spin the tires all the way thru the burnout area (you should hear an awesome screach !!!)
then practace launching around 3-4Krpm slipping the clutch the first 40-60foot
alot of people will tell you that doing a burnout on "Street" (all season) tires won't help
those people don't cut 1.8x 60' times on there cars stock
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
