So wats your mods?? And wat do you run??
I've never seen a stock 05-06 trap 108...I've seen them around 104-107 in my area (st. louis) usually slower then that honestly....there are a **** ton of people that cant drive
I ran a 13.9 my first pass (with about 1500-2000 miles on the car)
later that day ran 13.2 (I think I trapped about 107mph)
car wasn't completely stock (I had magnaflow mufflers (not catback, just mufflers))
otherwise stock
otherwise stock
Mods and times in the sig 2004 GTO best so far with all listed mods except clutch and 85mm TB is a 12.63@111.26 with a bad 2.0 60ft that was on the stock clutch on its last leg would only hold 4k launch so looking for 12.4 on my new clutch with better 60ft and added 85mm TB
#33
I am in Jimmy's boat. Power easily for the 9s but will be running hight 10s low 11s.
408 TT, Pedders XA's w/Track II, Hendrix 2piece driveshaft, Cryo Treats axles and stubs, too much else to list.
#35
t/b bypass
160 stat
pacesetter long tubes
catless mids
05 stock catback with muffler delete
drag bags
untuned on regular everyday tires
13.15 @ 110.85 mph
2.002 60ft
Just installed an LPE intake and ms4 cam going in next week followed by a dynotune
160 stat
catless mids
drag bags
13.15 @ 110.85 mph
2.002 60ft
#37
cam,headers,stall,used vette heads and the trusty old 150 shot...
http://www.youtube.com/watch?v=IB9sJ_W6QDY
#39
stock short block, 234/236 cam, headers, 100 wet shot, one piece ds, drag bags, shocks, springs, stub 2 hub, harrop cover, stock gears, built t56.
11.18 @ 122 with a slipping clutch, 1.61 60', best mph is 126.
