Pontiac GTO 2004-2006 The Modern Goat
So wats your mods?? And wat do you run??
Old 02-22-2009, 06:13 PM
RacerXLs1's Avatar
Arrow So wats your mods?? And wat do you run??
Just bored and figure i'd make a new thread.
Old 02-22-2009, 06:24 PM
Insane's Avatar
mods in sig and gonna run a high eleven!
Old 02-23-2009, 08:35 AM
Commissar's Avatar
Cam, headers, proxses tune, drag bags, shifter ran a 12.211 without getting into 4th gear, should be high 11's this year!
Old 02-23-2009, 10:00 AM
geeteego's Avatar
Stock. Mid 13's.
Old 02-23-2009, 10:19 AM
Texas Heat's Avatar
Originally Posted by geeteego
Stock. Mid 13's.
LIAR!!!
On my last setup (Stock LS2/GT70 turbo @ 8psi/ STREET TIRES) I went a 12.2 @ 123 with a 2.3 60ft spinning into 3rd gear.
On my new setup (Built 408ci/PT88 turbo @ 14-15psi/ MT's) I better see some damn low 11's to high 10's. (Until I build the driveline, then this bitch is coming off the two-step at 5500K rpm's boostin!!! 9's or bust!!!)
Old 02-23-2009, 05:32 PM
04BlackGmc's Avatar
time is in sig
SLP LMII,catless mids,Iat relocation,160* Thermostat,P&P TB,Noltec diff bushing,descreened maf,coolent bypass,JHP tube with k&n and ported air box,tune,
no times since the rest of the mods
Old 02-23-2009, 05:36 PM
geeteego's Avatar
Originally Posted by GTO JIMMY
LIAR!!!
88??? Holy crap Jimmy.
I'll let you know how my 2-step works out this coming Friday with the ET Bias plys. It'll be nice leaving on boost. Maybe a 12.90? LMAO
Old 02-23-2009, 05:40 PM
Summerwolf's Avatar
Had ruff r280 rims with some sumitomo htrz II, pacesetters, slp lm1, and a cai box and tune and went 13.2 @ 109 with a 2.31 60 ft....
with the current setup I'm shooting for much better
Old 02-23-2009, 06:31 PM
04BlackGmc's Avatar
didnt you have a bunch of suspension and bolt on's and headers?
just asking.
Old 02-23-2009, 06:37 PM
my first GTO's Avatar
http://www.youtube.com/watch?v=7b7VfzRbaG4
This was a 10.20 pass at Pinks ....we have gone 10.00.3@136
we have a 112HH and a 75 shot with a turbo 400....Frank
Old 02-23-2009, 07:41 PM
Devinsgn's Avatar
Long tubes and no tune 12.695
Old 02-23-2009, 07:48 PM
Texas Heat's Avatar
LOL yes sir I aint messing around anymore!!! Let me know how that two-step works, try and get a video!
Old 02-23-2009, 09:00 PM
Summerwolf's Avatar
just asking.
Did you not read what I posted. Pacesetters (headers) SLP LM1 Coldairinductions.com cold air box and tuned.
I had pedders springs and koni shocks yeah, and then the staggered Ruff R280s with sumitomo HTRZ II. Even stock clutch then too.
My car didn't use to have a whole lot done to it. Now its a heads/cam car with a better clutch, full suspension, ported throttle body/MAF, different air intake, weight reduction, and some sticky tires.
Old 02-23-2009, 09:35 PM
04BlackGmc's Avatar
sorry i was just asking i just remember you posting it awhile back on ls1gto.com and i thought you had more mods.
Old 02-23-2009, 10:18 PM
Legal Tender's Avatar
mods;
112HH Maggie with 8lbs of boost
JBA Short tubes
JBA catless mids
K&N
LPE 255 pump
Drag Bags
275 nitto 555r's
2 Bar speed density, self tuned on the street.
The rest is stock engine, trans, suspension, drive line, gears, converter, etc.
Full weight plus a little extra stuff in the car.
Pump gas.
60ft 1.716
1/8 7.618
mph 92.55
1/4 11.874
mph 116.38
Old 02-23-2009, 10:26 PM
CoolAid's Avatar
LS2/4L65E. Ported/Polished Intake & TB w/ 92mm inlets. 4'' Dynomax Ultra Flo race bullets. 160' thermo, Fan adjust and -50% TM.
12.98@108 at 2,200ft Density Altitude. 1.9 60' on stock tires with 15-20% tread left.
Just put on Kooks 3/4'' catless LTs and Nitto 275 DRs. Mods going in are Top Gear Motorsports built 4L65E and a Circle D +4C 4,000 stall converter. Hope to see low to mid 12s.
Old 02-25-2009, 04:45 AM
KrautBurner's Avatar
11.6 @118 on 1.6x 60'
40,000 miles, 300+ passes,
stock clutch
stock driveshaft
stock cv axles/stubs
stock springs
stock wheels
full interior
full tank of gas
Hotchkis Anti-Sway Bars
M/T ET Drag Radials 275/40-17 @ 20lbs
K&N FIPK
cam (in sig)
Speed Secrets (SSEFI.com) Tune
Kooks 1-7/8" Long tubes (with cats)
Borla Exhaust
Nitrous Wet Plate kit (100 shot)
Lou's Short Stick (short shifter)
and lots, and lots of practace
Last edited by KrautBurner; 02-25-2009 at 04:47 AM. Reason: don't forget lots of practace !!!
Old 02-25-2009, 11:19 AM
Stone Cold Goat's Avatar
Mods in sig. Hope to go mid 11s on ET Streets. Cam-Only
Old 02-25-2009, 12:54 PM
BAAD LS2's Avatar
Ran 13.01 at 108 w/ 1.9 60' with LTs and tune on street tires.
Cam goin in soon, hope to be mid to low 12s with DR's, maybe better with the driver mod.
Old 02-26-2009, 01:04 AM
Bonestock!'s Avatar
^^ 108 , you def have have the MPH to run a high 12.
Quick Reply: So wats your mods?? And wat do you run??
