My $3500 twin turbo kit made 564 hp!!
The only videos I have of that cavalier are when it was custom rear mounted and untuned running 6 psi. Never got any good video of it unfortunately. This run was 1 of 2 or so that I even have of the car. Later found out that the car had a nasty boost leak by the rear axle about the size of 1/2 a dime. Went pretty good for a cavalier though.
Theres a vid of it... Cavalier Z24 5 speed 3400 swapped t3/t4 rear mounted 6 psi vs. I believe an air filter only GN.
<embed src="http://videos.streetfire.net/vidiac.swf" FlashVars="video=5f9c4937-9760-4cb5-9ec5-995900293573" quality="high" allowFullScreen="true" bgcolor="#ffffff" width="428" height="352" name="ePlayer" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed><br /><a href="http://videos.streetfire.net/video/Cavalier-z24-3400-swap-6_122842.htm">Cavalier z24 3400 swap 6 psi boost t3/t4 turbo rear mounted NO tuning Just bolted on VS. Gran National GN turbo</a>
#33
damn nice set up but you guys can trap all you want.
it is not impressive.
a guy around here has a turbo gto makeing 800 plus rwhp running 140 @ 11.80's not impressed i ran 11.29 @125 with half the power.
make the car 60 then build some power. otherwise you are wasteing money
