need help bleeding throwout bearing 2004 gto
like it says, need help!!!!!!!!!!!! i can not find a bleed screw
this is in a swap using a wilwood master cyl. have the hose hook up ready to bleed and now i cant find the bleed screw. any help will be great. thanks.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
here's a picture i took of my remote bleeder hose in the bell housing. the stock bleeder screw is in the place noted. the screw extends right up to the hole. it's the hole above where the hydraulic line goes in. you need to feel for it tho 'cause you can't see it from under the car.
![](http://i92.photobucket.com/albums/l40/svede1212/mods/bleederandssline-1.jpg)
