Need help identifying vin engine came out of
Hello, I need some help proving the 17,000 mile 5.7engine I bought came out of the vehicle (04 GTO) I was given the vin to. The VIN is 6G2VX12G94L286699
I cannot come up with a vin derivative based on the info below and the same is true for the transmission.
The engine has a casting number of 12561168.
In front of the (right) passsenger side head there is a laser etch that reads VF040620873.
On the rear of the (left) drivers side head there is a sticker that reads:
4MB
104MBK040620873.
On the drivers side opposite of the starter the pad reads:
K256
904
Thank you.
4MB
104MBK040620873.
K256
904
Thank you.
4MB
104MBK040620873.
K256
904
Thank you.
4MB
104MBK040620873.
K256
904
Thank you.
Go here to decode the 2004 GTO Vin number http://ultimategto.com/cgi-bin/stats...4&f1=vinmatrix
The block casting matches a LS1/LS6 Block
Your passenger side Cylinder head should have a 241 stamped in the lower right corner, if you are looking at the head.
