CV shaft replacement
Hey anybody got any step by step instructions on changing the cv shafts on an 04 GTO. i have a general idea of what its going to take i just need to see what im running into.
An 8mm Allen, Torque wrench, and new tty axle bolts. Pretty straight forward. Don't even need to remove the wheels. Lift the car, unbolt the axle to stubs on either end and remove. Install new axle and torque all the tty bolts to 60ft lbs. per the TSB for loose rearend bolts.
an 8mm allen, torque wrench, and new tty axle bolts. Pretty straight forward. Don't even need to remove the wheels. Lift the car, unbolt the axle to stubs on either end and remove. Install new axle and torque all the tty bolts to 60ft lbs. Per the tsb for loose rearend bolts.
