Pontiac GTO 2004-2006 The Modern Goat
Question
Old Feb 6, 2010 | 02:40 PM
The Silver Goat's Avatar
Default Question
I read in a thread somewhere placing the key in the igintion charges the battery in the key.
True or false?
Old Feb 11, 2010 | 03:26 AM
breze84's Avatar
I dont think so... I have heard someone say that before though....
Old Feb 11, 2010 | 06:41 AM
tom's2005gto's Avatar
and if you hold the fob at your chin while pointing the key toward your car you get better range with it too.
and, if you hold the t/c button for 30 seconds, you will activate the factory power mod chip in the bcm.
Old Feb 11, 2010 | 07:24 AM
JAX04's Avatar
Classic. lol
Old Feb 11, 2010 | 11:52 AM
RitcheyRch's Avatar
Not true and the battery can not be replaced. When the battery dies you need a new fob.
Old Feb 11, 2010 | 12:25 PM
bigredgto's Avatar
not enitrely true. there's a thread on another forum showing how to replace the battery in the keyfob. it does require some soldering though
and to the OP, there's no truth at all to that. i wish it was true, as then maybe all our key fobs might work better.. but no
Old Feb 11, 2010 | 04:17 PM
On a side note, IF you have an after market alarm that is wired up to unlock doors, pop the trunk, etc. then you don't need to worry about a dead battery in your factory fob, as it is only used for such features, not starting the car.
Old Feb 11, 2010 | 04:51 PM
danieloneil01's Avatar
If I had an aftermarket alarm I sure as hell wouldn't use that gigantic key anymore. lol
Old Feb 11, 2010 | 06:13 PM
^^^^ unfortunately, even with an after market alarm, the key & fob are needed to start the car. Although LSPWR is working on something to fix that.
Old Feb 11, 2010 | 07:05 PM
LOL, good to know.
Old Feb 12, 2010 | 01:36 PM
1904gto's Avatar
i swear the chin trick works!
