Summit Radiator
Yea, mine fell to the common GTO radiator cancer that seems to be going around.
Figured I might as well get an aluminum in there so it doesn't happen again.
I just need one stat...
You will have to make it fit. I ordered the Griffen brand from Summit but they come with no mounting tabs of any kind. You can measure out your stock radiator and get a core that is very close in size that fits in the OE location.
If you are unsure if you can tackle a job like this, then you might be better off pulling out your retirement savings so that you can pick up the Hendrix piece.
