Pontiac GTO 2004-2006 The Modern Goat
fat and skinnes
Old 09-16-2010, 09:18 PM
gconnoyer's Avatar
nope they fit over the big brakes just fine Steve
Old 09-16-2010, 09:58 PM
9sectruck's Avatar
what is the reason for changing the studs??
Old 09-17-2010, 08:19 PM
1SLOCV8Z's Avatar
i run extended studs for added safety.
heres some pics of mine 15x4 15x10
Old 09-18-2010, 09:12 PM
TurboAv's Avatar
Greg Weld 15x3.5 front and 17x9.5 rear. Fits over the 05 brakes no problem.
Old 09-19-2010, 06:46 PM
c5formula's Avatar
so the skinnies off the front of an f-body will fit on our 05 gtos?
Old 10-12-2010, 11:50 AM
badpontiacs's Avatar
Yes. F bodies use a 1.75 bs on the front, along with the goats. The rears use a 7.5bs on a 10in wheel and 5.5bs on a 8in wheel.....same as an lt/ls f body. Hope this helps you a bit.
Old 10-12-2010, 05:12 PM
9sectruck's Avatar
ok im looking at the center line qualifier or the revs 15x10 rears, going to a full slick all time as my car is 100% weekend warrior/track, its only seen rain from inside the shop, so what is the right size tire for this set up with no cutting/beating on ****, thanks for all the input guys, looking to get in the 10s on 100stock long block no bolto on minus blower and a
tune
Old 10-13-2010, 11:34 PM
Commissar's Avatar
Greg Weld 15x3 and 15x 8, offsets as mentioned above. No grinding on required to make fit! Running MT ET Drag 26-10x15, now those require drag bags or spacers, they do stick out of the wheel well a bit. Well worth it at the drag strip though! Nothing like 6k+ launches!
Old 10-16-2010, 04:54 AM
twin turbo barge's Avatar
Thumbs up
That is pretty sweet mate
Old 10-18-2010, 04:30 PM
NA$TY-TA's Avatar
That BOM is perdy.... makes me want a set.
Kyle
Old 10-19-2010, 09:32 AM
1SLOCV8Z's Avatar
thanks for the comments guys its my daily
Quick Reply: fat and skinnes
