Ignition lock cylinder jammed.
Car is the 04 GTO in the sig,when i put the key FOB inthe ignition it will not turn.Sprayed lithium grease in there and worked the steering wheel and just will not move.I have no problem buying a new ignition lock for 60.00 Bucks,but the problem is i have to take it to the dealer to get re coded anyway.I don't even know if i can load it on my trailer with the steering locked to go to the dealership.What are you guys doing for this problem???
when mine sticks i push on the key as hard as i can into the cylinder while i turn it and it usually frees up.......
i dont know how better to describe it than as the cylinder turns it retracts into the column at the same time
Now you have my attention
To prevent this from happening again do this.
http://www.ls1gto.com/forums/showthr...ght=dremel+mod
Happens quite frequently on the goats. It's worth it when you don't have to worry about it anymore.
Just picked up the Goat from from the Pontiac dealer,it was not as bad as some cases i have heard.They charged me $50.00 for the cylinder and another $200.00 for 2 hours labor.As soon as i got home i sprayed lithium greas in there just to be safe.There is nothing you can do in this situation because the dealer has to re code the new cylinder to your old key FOB AFTER INSTALLATION.
my key fob never had to be re coded and ive replaced my ignition cylinder 3 times. When i bought the cylinder key switch, it came with the key tumblers, i just matched them with my old and it works perfect.
For you and other on lookers reading this if your key gets stuck.wont turn keep trying give it some back arms/muscles and or let the ignition cool down and get cold and might budge better. Dont right away get it towed and have a dealer mess with it you pay all that money, but you can buy and just need the cylinder ignition lock for 30 bucks at http://www.gmpartsdirect.com/. You dont need the whole kit that includes the tumblers and all that coding crap.
So once your able to finally get the key turning, soon as possible before the rut/pit gets really worse where for sure you'll need to get the whole steering column replaced follow the steps in the other link above and remove the old cylinder lock and before putting in the new one grease it all up and you be good to go.
Or like what i did is dremel grind down the pit/rut to make it smooth and still use the old one thats what i did.
Here a good video for you:
http://www.youtube.com/watch?v=Yz_BTfL4SFc
