Pontiac GTO 2004-2006 The Modern Goat
Track trip After mods. Input wanted
Old 11-10-2011, 08:30 PM
  #41
04gto5.7's Avatar
GCONNOYER i know at my power level i shouldnt have broke that ****. it didnt wheel hop i know what that feels like it just hooked and broke i didnt make it past the tree. also the shaft was a clean break and it broke at a downward angle so that leads me to the carrier bearing bound up which caused it to break. i broke where the main shaft goes smooth and starts to spline for the output
Old 11-10-2011, 10:24 PM
  #42
gconnoyer's Avatar
Originally Posted by clonedws6
So if i get the big side wall tire i shouldnt break anything? Even if i put the trex in my car? Also all i can find on jegs is 15 inch tires. and no 28x10s
How about these tires?
http://www.tirerack.com/tires/tires....O&autoModClar=
No those are a stiff sidewall road racing tire.
Here's the wheels you want
http://www.jegs.com/i/JEGS-Performan...ductId=1231935
And here's the tires you want.
http://www.jegs.com/i/Mickey-Thompso...oductId=746895
Might want to try and find something a bit more narrow if you're on stock springs or dont have drag bags.
Here's what it looks like
Old 11-11-2011, 02:13 AM
  #43
clonedws6's Avatar
SICKKKKK!!!! Im completely stock suspension with no bags as of yet
Old 11-11-2011, 05:54 AM
  #44
clonedws6's Avatar
http://www.youtube.com/watch?v=G_rEYmYnstE
This is vs an 02 wrx that went 13.4 at 105 on 12 psi. Hes now tuned for 17psi
Old 11-11-2011, 07:37 AM
  #45
04gto5.7's Avatar
what kind of suspension mods do you have to fit that i wish i could see your pics but im in afganastan and cant see it due to the crappy internet. so i guess im asking does it rub or anything like that
Old 11-11-2011, 01:51 PM
  #46
svede1212's Avatar
Just get some Mazda MPV Airlift drag bags and you should be good to go with those wheels/tires. One thing to be aware of is "lane walk". It's more like chit your pants sometimes if you get it. The back end will start feeling like it's coming out at the fast end. Definitely will wake you up. Bias plies for the front will help a lot. They don't recommend running bias and radial on the car at the same time. Some have gotten the spare tire wheel and some skinny bias front runners or you can do matching "Stars" like Greg did. That will also give less weight and rolling resistance and can help a lot too.
Old 11-11-2011, 02:17 PM
  #47
ShoddyHog's Avatar
I also recommend replacing the shitty stock rear springs regardless of whether you track it or not. It would have been my first mod had I known how much body roll it corrected. I have Pedders 0-Drops and the airlift bags...I also have a very nice writeup on the install at ls1gto.com.
Old 11-13-2011, 11:53 PM
  #48
gconnoyer's Avatar
I have BMR Drag bags and Pedders 5/16 Drag Springs. I would have just settled with the drag bags, but my stock springs were so worn out and worthless I was getting camber wear on my rear tires.
Old 11-13-2011, 11:55 PM
  #49
gconnoyer's Avatar
Definitely get a bias setup on all 4 corners.
ALOT of people run the factory spare wheels (which is perfectly fine) and actually run the spare tire.
I wanted to whole setup so I went ahead and bought it all off Jegs. Probably totaled $1200ish brand new.
Old 11-14-2011, 05:36 AM
  #50
clonedws6's Avatar
Why didnt you read his post where he linked those and the wheels?....
Old 11-14-2011, 08:29 PM
  #51
Roel Aguilar's Avatar
Dude I got a heck of a deal! Any new mods?
Old 11-15-2011, 10:58 PM
  #52
gconnoyer's Avatar
Nothing powerwise yet.
Hopefully this winter!
Old 11-18-2011, 04:55 PM
  #53
clonedws6's Avatar
Would these fit under my car on the stock 17in wheel?
http://www.mickeythompsontires.com/s...?item=ETStreet
Old 11-18-2011, 06:07 PM
  #54
gconnoyer's Avatar
Probably not with the factory springs
Old 11-19-2011, 01:35 AM
  #55
delphigto's Avatar
I run Hoosiers 17 drag radial and they hook. They hook well enough I blew through a monster stage 3.5 my first run. No wheel hop though. You don't need a bias ply tire if you get the right radial.
Old 11-19-2011, 12:02 PM
  #56
clonedws6's Avatar
Link to the tire youre running?
Quick Reply: Track trip After mods. Input wanted
