Full weight drags times?
I have a Stock suspension,full interior Goat and I was wondering what are some of the fastest ET and 60's you guys are getting?The car has heads ,cam,intake,A4 etc....
Our 2001 Monaro weighed in at 3,860lb and ran as quick as 11.79 and as fast as 117.8mph with a 243 headed LS1.
New times are with a cammed LS3, current weight is 3,880lb.
I don't think many people actually run the car full weight. It's so easy to pull things like the tow brace. Between the the passenger seat, back seat, spare/tools, tow brace, skid plate, and gas tank brace that's worth .2 in the 1/4.
My car at 3575 with 3.91s feels downright nimble.
If you got the power, it can go in the 8s full weight.
For your setup, I would imagine in the mid-high 11s. That all depends on what type of stall and tires you have, as I've seen max effort N/A cars go mid 12s because they had no traction and I've seen cam only cars go mid 11s because they had great traction.
My car rolled the scales at 3995 and went 11.1, that was with cam and 100 shot on the stock gears, M6. I pulled some weight out of it, but when you add a rollbar and scattershield you gain everything right back.
These are some pretty good ET's and 60's im stuck on 11.4 with a 1.7 . I really need help with my 60' because no matter what I do ,flash converter,load it up I get the same result.
