GTO Track times?
My last run was 12.9 @ 115. I have not been able to get any traction whatsoever with the nittos (245) I just bought a set of MT ET DR 275/40/17s and should be able to hook a little better. Then I can finally turn the juice on and really see what this can do.
#34
12.5 @ 122 with a 2.3 60ft..... something about 245 kuhmo's, a slick track and 600rwhp dont add up to fast times lol. I spun all the way to third gear and a little in the beginning of third.
#36
stout times, should be scary w/the bottle
12.1 @ 122mph w/2.0 60 ft
(not spraying 1st gear which is 0-50mph, and stock converter)
some stock ls2 heads should be going on w/a thinner gasket for a little compression boost soon.
and debating on turning the 125 shot into a 175 shot.
Then after that it's time to get a new Daily driver...this one is getting tired.
#38
11.77 @119
one of the last good runs before the clutch(spec st3) started slipping had just got the launch figured out to dam it
mods big cam, fast 90, lpe,ram hd clutch(now),gmm rip shift,sw LT's, E cutouts, Drag bags(I found a couple psi can make all the difference in the launch)
at the time of the 11.77 the car had arelli mezlen 19" rear tires with 275 General exclaim tires. no cutouts, 10 series mufflers. Can't wait to go back next summer with my 18" and drag radials
#40
