Pontiac GTO 2004-2006 The Modern Goat
Will Stock 16X8 2000 Camaro Z28 rims fit 04 GTO?
Old 12-20-2004, 05:56 PM
SDB
SDB's Avatar
Default Will Stock 16X8 2000 Camaro Z28 rims fit 04 GTO?
Will the 16X8 Camaro rims (from 2000 Z28) fit on 2004 GOT? Thinking of using some MT ET Street Radials on a couple of diferent cars. Thanks
SDB
Old 12-20-2004, 07:44 PM
FlyinGTP's Avatar
yes they will, i had 97-98 Z28 16 inch wheel's on my car all this summer.
Old 12-20-2004, 09:05 PM
SDB
SDB's Avatar
good to know, thanks!
Old 12-21-2004, 11:15 AM
Rob
Rob's Avatar
Did you use them for everyday use or just track use? Any lug nuts loosen up while they were on?
I'd really like to change to some other nice factory wheels and just worried about the little difference in bolt pattern. I'd have no problems running them in the rear at the track. But just wondering what everyday driving does to them.
Thanks for any info
Old 12-21-2004, 11:45 AM
Xsta Z 28's Avatar
Techincally NO.
GTO Bolt Pattern is 5 x 120 mm
Z28 Bolt Pattern is 5 x 120.65 mm
Old 12-21-2004, 08:11 PM
FlyinGTP's Avatar
I drove on them every day well as often as i drove the car but i put about 1700 miles on them with out them ever loosening up. No vibrations or anything either. I plan to put the 16 inch version of the 96-99 camaro ss wheels with the recessed centers on it for my summer tires. And keep the crappy flower power wheels for winter (yeah like the car has actually seen foul weather).
Old 12-24-2004, 10:28 AM
Closer_2001's Avatar
Thanks for any info
What size tires did you run with the 16"s I'm thinking for slicks at the track also
Old 12-25-2004, 11:21 AM
FlyinGTP's Avatar
255 50 16 mt et street drag radials. The most hookingest drag radial known to man.
Old 12-26-2004, 01:39 PM
Pontiaker's Avatar
A .65 mm difference in the bolt circle is not going to be a problem, I saw a guy running these on another forum and he was also not having any problems.
Quick Reply: Will Stock 16X8 2000 Camaro Z28 rims fit 04 GTO?
