Pontiac GTO 2004-2006 The Modern Goat
New GTO 1/4 mile time
Old 02-20-2005, 07:07 PM
WAHUSKER's Avatar
Default New GTO 1/4 mile time
I took my goat to the track today to see what it would trun. I knew it was slower than my TA was stock, but I didn't expect this much difference. It ran 14.6 @ 92.6. Now I did try to shift 2-3 manually because I thought it shifted too soon out of 1st, and I hit the rev limiter & had to let off to get it to shift, so it probably would turn 14.5 @ 95. Which is almost exactly what my moms 69 Road Runner ran stock, so I guess it's OK. Just slower than I thought.
Maybe when it gets some miles on it the times will get better (at 500 miles now). The TA really woke up when it hit 5k miles. But hey, it's the wife dd so who cares, right?
Old 02-20-2005, 07:20 PM
-=RampageRed2K5=-'s Avatar
Practice more you should get around 13.6 to 13.8 good luck!!!
Old 02-20-2005, 08:19 PM
Moderator
xp3nd4bl3's Avatar
It should be good for 100mph what was the DA at the track?
Old 02-20-2005, 08:29 PM
CessLord's Avatar
Omg! those times are terrible. Do you know how to drive? I'll assume you were having traction probs.
Old 02-20-2005, 08:44 PM
WAHUSKER's Avatar
No traction problems, & yes I know how to drive, but the car had 450 miles on it + a full tank of gas & I aint a little guy. I figure it may go low 14s when it's broken in, but I was thinking it shold run hi 13s. Maybe I got a dog.....I dunno.
Old 02-20-2005, 09:03 PM
CessLord's Avatar
I really hope you work it out man. I fell in love with this car. Made me park my Challenger. I really should not be talking about times.. I have yet to take my goat out to the track.
Old 02-23-2005, 03:09 AM
2000 S6's Avatar
keep trying...u will be in the 13's in no time!
Old 02-23-2005, 09:13 AM
CMNTMXR57's Avatar
I keep posting this.
My 98 Camaro ran 13.7 @ 101 stock. My GTO ran 13.7 @ 103 stock.
Granted I have an early LS1 powered F-Body, but nonetheless...
Old 02-26-2005, 01:19 PM
bobby777's Avatar
Nickname goat. When have you seen a goat run fast. The major problem with 04/05 models is just flat to heavy by about 400 lbs.
Old 02-26-2005, 02:20 PM
It's not mine! woo hoo!
demonspeed's Avatar
I would have been breaking stuff if my car would have gone 13.7 @ 101. That's messed up.
Old 02-26-2005, 02:41 PM
black_z's Avatar
101 is a really low trap for an LS1 F-body.
Old 02-27-2005, 10:28 AM
NVigR8's Avatar
'04 GTO should be a mid to low 13 sec car. My m6 '04 picked up a lot of power in the butt dyno after a few thousand miles and I was able to run 13.1's multiple times. Maybe it just needs to break in a little. Also the a4 torque mgmt kills your time - you get can that fixed with a tuner.
Old 02-27-2005, 11:00 AM
WAHUSKER's Avatar
True, my TA really woke up when it hit 5k miles. And TM is going to go as soon as I add the goat to my HP Tuner. It shifts worse than the TA did stock. And then there is the NW factor. Cars up here just seem to run slower, which doesn't make sense since we are at sea level & have nice cool moist air. The day I ran the DA readings were -266!
Old 02-27-2005, 11:08 AM
CHarris's Avatar
It might be that we in the Northwest BS less Go run it again and let it shift itself just to be sure it's a good time to be quoting.
Old 02-27-2005, 08:03 PM
qwk93ta's Avatar
What kind of 60 did you pull?
Old 03-09-2005, 04:01 PM
dubrado's Avatar
With 1500 miles, my A4 ran 13.9@99 w/a 2.0 60ft, it weighed in at 3950 w/me in it during that run
just wait til you get over 5k on the motor and it should open up a quite bit more
Old 03-10-2005, 06:56 PM
mulletwearingtadrive's Avatar
an early LS1 powered fbody? like that makes a difference..... they are so much slower than the 01 and 02.
Old 03-11-2005, 04:14 PM
NC Guy's Avatar
I ran a 13.46 @105.8 in my bone stock 00 SS M6......Granny shifting no less!
Didn't think that was too bad on rock hard stock rubber.
Old 03-11-2005, 04:51 PM
demonspeed's Avatar
13.5 @ 106 for my 2000 with 12k miles on the odo.
Funny how that is since we "only have 320hp"
Old 03-12-2005, 03:55 PM
B-MAN's Avatar
LS1 motors have a safety chip in the CPU. It doesn't sound too detrimental percentage wise, but it does make a difference at the track. This is how it goes
Until the car reaches 500 miles you only get 90% of your over all power,
at 1500 miles you get 95% of your over all power, and at 2300 miles you get 100% of you over all power. this is to aid in breaking in the motor, since new cars do not come with special lubeicant to break in the motor like in the old days.
This is what my friends father told me, I guess he works for GM. However I do not know how creditable this statement is. I am just the messenger.
Quick Reply: New GTO 1/4 mile time
