MTI's NEW Pontaic Stroker Motor - 455!
Ah yes, if only I had $20k laying around.....does this sound like an interesting setup. Talk about an open road motor. Tho I'd be putting it into my TA not my GTO.
455 ci with 605 hp & 610 lbs of tq out of an LS1 motor. DAMN!!!
http://www.motorsporttech.com/
Click on the Online Brochure about it. Looks like they done it right too. All new steel crank, billet steel barrel-shaped beam rods (all Lunati), MTI G1 custom cam (228/232, 588/574, 113), forged pistons, stage 3 LS6 heads, etc etc....
The 455 they did at idle has 400 rear wheel HP just off idle and then from 3,500 to 5,600 RPM it has over 500 rear wheel HP and redlines at 6,800 RPM. At least that is what 'High Performance Pontiac' had to say about it.
That is pretty freakin awesome.
For $19,995 I wish I could afford it to put in my WS6.
This is a Very BAD *** 455 LS1.
Originally Posted by BBM6
I know the package is available for the GTO, but is it available for anything else? It would be cool if it was....
It is still a 350 and I am sure it would fit in my F-Body. They probably do not have a kit and some thing would need to be done liek maybe relocating the A/C. But, why not?
ther is a company in West Aus that is putting the final touches on there 454cu motor/ new cast alloy block not a stroked version of the ls1 but will be a oem replacement for them. will try to find the company name pretty sure it is Kostecki would be great replacement as well not sure of price though.
try www.kec.com.au if you want to check it out
