Pontiac GTO 2004-2006 The Modern Goat
broke rearend
Old 07-20-2005, 07:11 PM
sickfirehawk259's Avatar
Default broke rearend
my driveshaft and rear end blew out 2 weeks ago now gm is telling me they will not cover it they said there is rubber in the wheel wells and asphalt on rearend i never hit anything could the rearend hit the ground when it locked up and broke the driveshaft am i screwed or what can i do the car has 6500 miles on it thanks for any help
Old 07-20-2005, 09:19 PM
04LS1GTO's Avatar
call the reginal rep and get him involved
Old 07-20-2005, 10:05 PM
ULTIMATEORANGESS's Avatar
how exactly did these failures occur?
is there rubber in your wheelwells?
Old 07-20-2005, 11:40 PM
Moderator
xp3nd4bl3's Avatar
You put it on a slick and didn't pull the rubber off before taking it into the dealer?!
Old 07-20-2005, 11:48 PM
no just street tire rubber not a lot the gm rep is involed
Old 07-21-2005, 01:20 AM
CSiJason's Avatar
Ok I have to not believe this a bit... Their is no way BOTH the drive shaft AND rear end broke at the same time. Either one or the other... The most likely stress point to fail would be the RUBBER coupling between the drive shaft and rear end. I believe BMR was running something like a 200 shot off the line going 10's before they broke their factory rear end. They never claim to have broke the drive shaft IIRC, but they upgraded their drivetrain to hold plenty of power. (And no doubt to sell more drivetrain components.)
Their are probably a dozen people on LS1GTO running STS or Prochargers, at least a few are running 11's, at least one STS person in the 10's on a stock drivetrain.
So exactly what did you do again? As for asphalt on the rear end?? K that doesnt make sence. Their is no way the rear end would hit the ground unless the car was dropped out of an airplane or something. The differential housing is bolted to the frame from the rear and subframe from the top. That puppy isnt going anywhere.
The only way I could even imagine the differential AND drive shaft might have broke at the same time is if you were being a knucklehead and yanked the parking brake while driving in gear causing the differential and driveshaft to take a massive shock load causing both to bind and break under the engines load still. Seeing as the parking brakes are uber touchy on the GTO, that would make a bit of sence, but still wouldnt make it a faulty component failure. (More like abuse, which is why I can see they wouldnt want to warrenty it.)
Either that or you have uber heavy 20's on the bitch and tried to do a burnout, instead the massive load of 65 pound wheels twisted everything into a knot.
Old 07-21-2005, 01:32 AM
no e brake it was making a ticking sound before the big bang
Old 07-21-2005, 02:10 AM
CSiJason's Avatar
Time bomb? Have you seen any strange looking people with a rag over their face around your car recently? Just kidding...
Sounds odd. I cant see why both would suddenly fail like that. Is it an 04 or 05? IIRC the rear gears and CV axles were upgraded on 05's.
Old 07-21-2005, 02:44 AM
JustAnIlluzion's Avatar
ashplat??? hmmm when i did a 3 min burnout in my dakota.. i dug like 3in holes in ashplat.. and that along with rubber was in my wells and axle prolly.
so how did u break it again? from daily driving? do u have a firehawk and gto?
Old 07-21-2005, 12:47 PM
yea i have a firehawk and a 2004 gto i do drive it hard but this is bull$hit what can i do now
Old 07-21-2005, 12:49 PM
i think the rearend locked up and broke the shaft
Old 07-22-2005, 06:58 PM
no they want to void the whole car
Old 07-22-2005, 07:01 PM
dubrado's Avatar
bitch at them or get legal help
they just dont want to cover you, a little rubber in the tire doesn't prove anything.
Old 07-23-2005, 12:48 AM
Nathan's Avatar
it's bullshit how they don't expect you to race the car
yet they publish 1/4 mile times for it everywhere
what the ****?
Old 07-23-2005, 01:12 AM
i know but what can i do? there is not even a lot af rubber in the wells they said i did a 6k dump to do that. when it broke i wasnt even beating on it. he said he heard i took it to the track but i have never had it to the track yet. u can bet this it he last gm i buy i just bought a 2005 tahoe and was going to order a new work van in the fall but i might go dodge i have about ten gm car and this is how they treat me **** them
Old 07-23-2005, 01:15 AM
CSiJason's Avatar
Legaly they cannot void the warrenty on the whole car. I'd demand they replace the broken components and then promply sell the car. I wouldnt mention the 'trouble' with it after it is fixed though.
Old 07-23-2005, 01:21 AM
who do i demand to i tried the dealer and the gm rep all they do is give me $hit
Old 07-23-2005, 05:51 AM
dubrado's Avatar
call in to customer service and try them
Old 07-23-2005, 02:58 PM
i did that got no were
Old 07-24-2005, 11:00 AM
04Yukonxl's Avatar
Get a lawyer. They respond well to legal letters. Threaten a lawsuit.
And, it does take a lot to break one of these, but GM has had diff problems with a few.
Quick Reply: broke rearend
