IRS wheel hop
Originally Posted by gametech
15" rims for drag radials aren't really an option over the wilwood brakes. I am thinking of putting a set of MT's on my stock rims for track use to save wear on the Nittos I drive with on the street. It will be interesting to see how much that helps.
Originally Posted by Dbluegoat
no they go in king springs and the pedders springs.....not just stock springs. I had the pedders lowering springs and was able to get drag bags in, then when I switched to the king springs they fit on those also
ALSO note your in an Auto, and not a 6 speed.
I Just Installed Spring Rubbers 1.25 60duro And Squat Is A Lot Less Neg Camber Less Ride Height A Tad Higher Ride Is About The Same.seems To Bite Better Now But I Havent Taken It To The Track Yet To See.had Real Bad Hop At Take Off And Into Second Im A 4a.yes We Get It Too.
