Need a help for heders
Go with some Kooks long tubes. Do not go with Stainless Works. I have SW on my GTO and those fing things hit on my power steering box/lines all day long. I orignaly tired to switch them to Kooks befor they were sent off to me but since they were coated I was not able to do so, as of today I'm still wondering if I should spend the money to switch to Kooks.
Kooks LTs, coated. PM me for where to get them at a decent price.
Some of all brands of headers have fitment issues IRT the steering. This is not because of the header but because of the car. The steering rack location varies as much as 1/4" from car to car. How much is 1/4 of rack movement as compared to the steering wheel? Almost 180 degrees.
The solution is move the rack to clear the steering arm from the header, then get an alignment. The only thing that will be wrong will be your steering wheel center. The alignment will still be as it was before you started. All that will need to be adjusted "to fix this part" will be your toe settings.
I have installed about 4 sets of these and all, even mine, required some adjustment to prevent binding on acceleration while turning left.
Jerry
Jerry
I have SLP long tubes with hi flow cats. They come coated and had no fitment issues. I had no problem to date with them . Never had a problem with anything from SLP yet. I would suggest to go catless for the extra power. It only took me 6 hrs with hand tools on the ground by myself. That was taking a couple breaks. I am a union guy, just can't work right thru any job. I had no binding either.
Jerry
Jerry
Originally Posted by GTO1_OHIO
Kooks 1-3/4 with cats ...best choice.
I just Installe SW LT's over the weekend, they were a pain in the *** to install. Make sure you have metric and sae stubby wrenches, they will make it easier. As far as fittment issues, they are damn tight, but they fit. I also think that now they have been heat cycled I can re-torque them and the one very small exhaust leak will go away. shouldnt have reuse my stock flange gaskets.
