Rubber Drive Coupling Info
![](http://i2.photobucket.com/albums/y20/PerthPurplePenguin/car%20parts/92148358.jpg)
Front & Rear Rubber Drive Coupling (Donut) Part No 92148358
Manufacturer Hardy Spicer
Mfg Part No RCA-1061
Comes complete with 100-R324 Coupling, 3 bolts, 3 lock nuts.
Holden VX,VY,VZ V8's 10/00 on
Pontiac 2004 only
PCD=96mm
Bolt Dia=12mm
OD=133mm
Bore=49mm
Width=35mm
Originally Posted by FastPacedGTO
thanks? price? i need a new pair.
There's other info I'm seeing saying the 2005 and newer GTO has a larger rubber coupling.......but nobody knows the part number.
If you do track it down (ring suppliers and quote your VIN) please post up the Part Numbers.
Thanks
92148358 seems like it's for 2004 GTO only.
Thanks
Thanks
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
