Ls2 Gto Guys Need Your Input
I did a search on LS2 cam GTO's and found this
https://ls1tech.com/forums/showthrea...s2#post5190075
My ? is
450rwhp really what to expect from a cammed LS2 goat.
For example
Lets say
I had a 05 GTO A4
Lets say I had the following mods.
CAI
LT HEADERS
CAT BACK EXHAUST
3200 VIG
AND A CAM (JUST PICK A CAM TO USE)
What kind of horse power could I expect from it?
What kind of ET?
Do people even do gears in these cars?
My ? is
For example
Lets say
I had a 05 GTO A4
CAI
LT HEADERS
CAT BACK EXHAUST
3200 VIG
What kind of ET?
How big of a cam. I went with an FTI streetsweeper II and made 432/398. That is with LT's, catless mids, and a "CAI". The specs on that one are 236 240 .630 .630 111LSA. I could have made maybe 15 -20 more with a FAST 90.
My cam is a 232/234 595. 598. @112lsa I have pacesetter longtubes, catless mids, lpe intake, and a 3400 stall. I made 408 rwhp 367rwtq. With the big cam and stock stall I went 13.0@109 ( car 0-30 was a dog on stock converter) However tomorrow night I will test out my new converter on some et streets I am expecting a 12.3-12.5@110+
Hell I am Praying I am at Least 450 with my set up
160 Degree Thermostat
PACESETTER Coated Long Tube Headers
PACESETTER Catless Mid pipes
CASPER – 02 Sensor Extension
Stolen Fox (Ryan) H Pipe
FLOWMASTER 44 Series mufflers
CASPER ELECTRONICS IAT Relocation Kit
PCMFORLESS.COM / Alvin Custom Tune
K&N Air Filter Kit
V&R Throttle Body Spacer
BSR FABRICATION Oil Catch Can
ASP Crank / Alt Reduction Pulley Set
ARP Crank Bolt
GOODYEAR Gatorback Belts
NGK Plugs – TR55’s
SCOTT Ignition Wires
REDLINE 5w30 Oil
COMP CAM Special Grind Bump Stick .227 .236 .639 / .602 LIFT
COMP CAM Valve Train
Phoenix Performance 3400 Triple Disc Stall w/Balloon Plate
K&N Air Filter Kit
ARP Crank Bolt
NGK Plugs – TR55’s
REDLINE 5w30 Oil
K&N Air Filter Kit
ARP Crank Bolt
NGK Plugs – TR55’s
REDLINE 5w30 Oil
K&N Air Filter Kit
ARP Crank Bolt
NGK Plugs – TR55’s
REDLINE 5w30 Oil
K&N Air Filter Kit
ARP Crank Bolt
NGK Plugs – TR55’s
REDLINE 5w30 Oil
K&N Air Filter Kit
ARP Crank Bolt
NGK Plugs – TR55’s
REDLINE 5w30 Oil
I will keep you posted, as of now this is whats done.
K&N Air Filter Kit
REDLINE 5w30 Oil
THIS IS GOING ON TUESDAY, and Weds it will hit the dyno to see what the gains are. Cam / Kit, and Pulley will be going on at a later date.
NGK Plugs – TR55’s
K&N Air Filter Kit
REDLINE 5w30 Oil
NGK Plugs – TR55’s
408RWHP & 380WRTQ is what I put down.
AZPS02 cam, LT's, no cats, exhaust, FAST 90 intake, dyno tune and Yank SS3600 stall is what I had then. I've since done a few things and I'm hoping that it makes 415RWHP and 400RWTQ.
