o2 sensors?
If I remember right the front O2's will not reach the bungs on the Pacesetters without extentions. The rears will reach but you'll want to turn those off anyway unless you got catted mid pipes.
You'll need to get a custom tune of some kind. Hand held tuner, EFI Live, HP Tuners, Dyno shop etc...
Otherwise you will trip a SES light because the O2's will see an off reading. Do you have cats in the mid pipes? If you do then I dont think it will matter.
It may goof around with your fuel trims. Sometimes I get some idle hunting when I approach a stop light and push the clutch in. Worse if the AC is on. Nothing too bad. Still easily driveable.
A tune is going to:
A. Turn off the SES light and codes that trip it.
B. Get you the extra HP by getting your air/fuel mixture optimized.
That is something these cars need before any mods anyway. That is why you see 20-35 rwhp gain from just a tune and headers most of the time. I have tuning software and I didn't turn the O2s off for months becasue I was too lazy to go outside and do it.
Short answer is: No problem to drive it. A tune will make it better.
A tune is going to:
Were you just gonna plug the front bungs with the O2s and not hook them up? That will throw a code and may affect driving because it is the front set.
The rear O2s just check for cat function. Where the front O2's are checking your fuel mixture.
There are also things called O2 sims. I don't know if they make them for a GTO or not.
No mater what youre gonna need to get the front O2s plugged in. They only way to do that is the extensions or cut your harness in half and solder in extention wires yourself. That is what came with my Pacesetters, a bunch of waterproof butt connectors and a small run of wire. Kind of ghetto, but I did it.
i got the o2 extentions. my mid pipes also have a spot for the rear sensors. so i am jut going to hook up all of my sensors for now. i want to get a tune after i am finished with all of my bolt ons. its a dyno tune not just a plug and play tune, i figure i wil be able to get more out of it that way.
you seem to know quite a bit. do you mind if i ask you some more questions? (1slowhoe)
I are smart
You can ask. Not saying I know the answers. For GTO specific questions I suggest a search at www.LS1GTO.Com Only because 90% of the guys on tech are F-body drivers. A lot of the theroies and parts are the same but the GTO has some very "non-standard" parts as well.
