Project Comments & Discussion Use this forum to discuss Sponsor projects.
add oil with 1960 style valve cover
Old 06-13-2019, 07:21 AM
Allan Garonzik's Avatar
Default add oil with 1960 style valve cover
Doing a restro--LS to 1954 Corvette. Want to add 1960 valve covers. How to add oil and breather without cutting valve cover?
Old 07-01-2019, 08:24 PM
LLLosingit's Avatar
Not sure what the valve covers you are going to use but it will need a place for the crankcase to ventilate regardless so you should be able to add oil there.
Old 07-13-2019, 09:47 PM
wannafbody's Avatar
Check Summit. Someone makes finned Corvette style covers for the LS engine.
Old 07-21-2019, 11:16 PM
CamaroRick's Avatar
If you run an air gap intake or carb style you can drill and weld a fill tube to the valley cover.
