Harness holes too small?
#41
BTW, did you get a 5 point or a 6 point harness? How do you plan on attaching the anti-sub belts of either one?
I have a 6 pt and I run the subs under my thighs and through the seat's lap belt holes and down to the lap belt mount.
Also, how to you plan on attaching the shoulder belts? Mine are attached to a harness bar.
#43
5pt. Anti-sub? The crotch strap? I have a crotch strap bar bolted to the front seat mounts.
Shoulder belts are wrapped around my cage.
#45
It sounds like you are doing everything correctly from a safety stand point.
The crotch strap prevents you from submarining under the lap belt during a frontal impact, which is why it's called the "anti-submarine" belt. It does take quite a load if it's every brought into play, so you can imagine what can happen to your body in that area. That's one of the reasons I went to a 6 point harness.
#47
#53
Man this guy WTF?? Hes considering GRINDING a bolt but not modding the tab??????????????
ANYWAY, I put my drag belts in the factory holes. But I wanted a straighter "pull" on the belts. If you use a straight "lace" tab they are pressed up against the floor when bolted down which makes the belts pull at an angle.
I found a place called Pegasus Racing who have tabs that are bent at an angle that you lace on the end of the lab belt they pull straight when bolted down.
I went to the bolt and screw store and bought grade 10.9 bolts and put in mine. SIMPLE!
Here ya go.
http://www.pegasusautoracing.com/pro...p?Product=2388
All KINDS of cool stuff on this site, enjoy!
Just incase yall wanted some 411.
Here ya go.
#54
Race your car!
You can get bolts that are the right thread right from lowes or home depot, just bring the existing torx bolt with you, find a nut that will thread on and then get the corrosponding bolt, simple.
If you still have to open the holes up a touch, the stone bit that a dremel comes with will do it, that's what I have used.
Opening that hole up, is not going to effect anything safety wise.
If you hit something hard enough to break that metal you're dead anyway.
#55
UM Let me get this straight! I didnt say not to enlarge the diameter of the hole. I was just letting him know a lternative that we did. Grinding just the shoulder of the bolt will not affect anything strong wise. Either way is fine and will work. If you snap a bolt that big or rip through metal that thick your internal organs are done anyways.
#57
IIRC, The RCI 6-point in my personal car bolted in without modifying anything. You may want to look into their tabs and just thread your harness' into them.
Danny
Danny
#58
Hey, lets keep things in proper prospective here.
In all seriousness, i haven't heard of a single person being hurt in a Madman chassis. if its 4th gen f-body chassis related, and i would say safety mount stuff is, if Brian says its ok, its ok. he's smarter than he looks(and acts sometimes), lol.
oh, and +1 for the camlock vs the latch style.
#59
Wow...this thread is ridiculous. OP may want to have his 5 point harness installed by someone else.
I might as well hijack it and ask some decent questions.
I am looking to buy a 5 point harness, and mount in a TA with stock seats and stock mounting locations, i do have tabs welded on my cage. So all you have to do is drill out the harness a little bit for it to work with the neck on the stock bolt? Sweet. Has anyone mounted thier seat belt and 5 point at the same locations? It would be nice to have both.
What do you do for mounting of the crotch strap? Drill a hole in the floor under the seat with a washer on each side?
#60
As far as the crotch strap, Madman makes a bar that bolts to the front feet on the seat mount. Or do like I did, there is a rib in the floor under the seat that sticks up, I drilled through the rib and installed an "eye" bolt with 2 THICK LARGE washers on both sides. I laced a "clip" on the end of my crotch belt and clipped it on the "eye" bolt.
