Harness holes too small?
Well that didn't work at all. Chewed up a couple bits, as the brackets are some kind of hardened steel or something. I really wanna get these in the car, anyone help?
That makes me worry about safety....
quoted from another site:
Why is this such a pain? I'm not the first person to put these in a camaro....so why is this so difficult? There HAS to be a better solution than this!
If you are dead set on using the stock mounting point, you only have 2 options. open up the hole of the harness or use the supplied hardware that came with your harness.
Opening up the hole is not that big of a deal. Your referenced link, while true, is probably a little over the top. If you take your time, be smooth and be careful, the issues javajoe sensationalized will be of minimal concern.
Using the supplied hardware brings along it's own set of issues. Primarily, installing the bolts or eyebolt in the rocker panel side. In my race car, I used a cut-off wheel and made an access panel in the botom of the rocker panel so that I could get a wrench on the backing nut after I installed the harness' eyebolt. Once finished, I made a cover and riveted it in place to seal the hole I created. I used windshield sealer to prevent water intrusion.
In my street car, I opened the hole of the harness tab with a die grinder.
I don't know what brand you sourced. I'm sure there are some brands out there that don't. It's probably how they can keep costs low.
I went out to the shop and dug out these parts. Compare the torx bolt from a 4th gen, which is a semi-coarse thread metric, with the fine threaded hardware I got from pitstopusa.com.
Not saying you are wrong, but I think it's worth a check to make sure.
Some fabrication is to be expected.
these are the specific ones i used. they also come in a shorter version, but same pitch. screwed right in, no problems. i havent swapped yet, but i cant imagine GM changing the pitch of threads between 3rd and 4th gens.
