Carbotech ?'s
The car is the Trans Am in my sig and it's no lightweight.probably between 3600-3700 lb's, 570 rwhp. It's not daily driven so noise/dust isn't much of a concern. It sees auto-x fairly regularly, some very long and aggressive back road driving, and will see some open track days this year.
I'm also flushing my brake lines too, any recomendations on fluid?
Thanks
with 570 at the wheels, i'd be looking to upgrade the entire brake system. The KORE3 corvette kit is pretty nice and reasonably priced. There's also the Bob Bishop bracket set that you can get from the frrax.com site. you can put c6 calipers on it. they hold up better than the c5's.
I've got Motul RBF 660, and my god I love it.
As far as brakes... well, I have a slow car so I have no need for anything more than stock calipers, solid rotors and a healthy supply of Hawks brake pads...
During a weekend, I would have to bleed my brakes Saturday night when I was running Motul or SB fluid. I just cooked the fluid. It would come out green and slimey.
Louis Gigliotti talked me into using a bottle of SRF and it was night and day difference. The only fluid I bleed now is when I replace brake pads about twice a year. I open the bleeder screw when I push the pistons back into the calipers and then top off the MC.
That regiment began in 06. So, I've spent $180 in brake fluid in almost 4 years and I still have about 1/2 the 2nd bottle on the shelf.
And the REAL benefit is I don't have to fuss with bleeding brakes at all. It allows me to concentrate on more important stuff, like shade and gatorade.
My rotor temps at the last race were 1432 degrees F. Apparently others have seen up to 1600. This winter we are finally getting old world challenge rules to play with (4 piston max front/rear) with 2 piece rotors with aluminum hats, so next year I'll get to save $ on pads and fluids with the new setups
I'll clarify so no one confuses anything...
I do not boil the SRF. Every time I bleed after my sessions the fluid is clear. I bleed so I get my stiff pedal back (if not just for the lap and a half it stays firm
). Literally between every session I have to clean up my pads due to insufficient cooling; heat which radiates through the rotors, into the calipers, and killing my pads (and pedal). But the coolant is good...just WAY overkill for a street car that does a little auto-x and a couple DEs. Super Blue works great in my street camaro and is pretty cheap too
what car? and what level of prep? I love rally and would like to get into it, but I can only do so much and spend so much $ i have tossed around the idea of finding an older salvage title audi or wrx and go have fun in it
