427 LS2 M3 on track at NJMP
Sorry about the crappy camera sound quality. Turning down the treble helps filter it out.
I was losing oil pressure in sharp left hand turns so I delayed getting on the gas until the pressure climbed above 30 psi in a bunch of turns.
![](http://ts.vimeo.com.s3.amazonaws.com/676/938/67693827_100.jpg)
http://vimeo.com/12151729
John
E36 LS2
John
E36 LS2
Yes, the car has the Improve Performance baffled pan. I'm trying to avoid a dry sump setup. There has got to be a way to do this with a wet sump setup but thanks for the feedback. Keep it coming.
Well, unfortunately the LS2 and LS3 block are just prone to oiling issues on high G left hand corners; even more so on sustained left handers. In T-1, the LS2 and LS3 Corvettes would blow motors left and right until the SCCA approved of them running a 3 stage dry sump. The batwing pan helped the LS2's a little, but not the LS3's. GM engineers did not design the LS3 block for consistent and/or sustained 1.2+ G corners. I'm not sure what the excuse is for the LS2 block. You can believe me when I say the guys I race with tried the extra quart, tried the 3qt accusump, etc. All that's worked is a 3 stage dry sump unfortunately.
Hell, a local guy bought an LS3 vette to run with us that had a brand new crate LS3 in it with accusump, and on his 1st test day with the car (2nd session) the motor let go; and based on his times, he was barely running the car at 80%
After this weekends event at VIR, I'm starting to warm up to a dry sump setup.. but not the potential price.
How hard is it to convert a wet sump setup to a dry sump? I presume the oil pump has to come out in addition on the pan... any tips?
I honestly don't know everything it entails. I know it needs a whole new pan, oil holding tank, and lots of lines. I'm sure the current oil pump needs to come out, and something replaces it, I just don't know what
Here's a lot of info: http://www.drysump.com/Products.htm
What I do know about dry sumps, is they are not easy to plumb, and if done incorrectly, you'll be blowing oil out worse than if you put a hole in the block.
Let us know what you end up doing
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
To configure a dry sump system, take a look at the Aviaid catalog since it contains schematics and some very nice explanations of systems, stages, etc.
http://www.aviaid.com/pdfs/cat05.pdf
Andy1
Andy1
This thread gives you the idea for costs: http://forums.corvetteforum.com/auto...es-or-not.html
wtknght1 is an east coast racer I compete with, he has an LS3
