Getting ready for auto -x have Q'S
I have added a ps cooler, tranny cooler and have read some where some guys are replacing the oil pan drain bolt plastic washer with a brass or metal one. Seems the plastic ones tend to want to melt? Any body replace or have any problem with the plastic washer? Thanks
I doubt you will have any issues with the plastic washer melting during Auto-X..
I have been running HPDE's where I have been running my car at high RPM's for 20-60 minutes at a time and have never had an issue. I however did ditch the stock PS cooler and switch to a 2 row Derale cooler mounted where it receives good air-flow. Pump has survived thus far.
I was looking into this yesterday. Do you have pictures of your setup? Perhaps a new thread to post the pics in? My car is 40% street, 40% aggressive cornering, and 20% drag strip, but I still don't want the stock cooler failing on me and dumping PS fluid into my coolant.
Not helpful... What I found was your post that said that Perma Cool is no longer around and that you used a Derale. No other topics centered around power steering cooler locations... Search terms used: derale cooler
I suppose I can dig around in the other cooler topics, though.
Look.in here and search again....
http://www.frrax.com/rrforum/index.p...teering+cooler
I put the Derale in lower right of my rad shroud, cut a hole and mounted it .
