Road Racing Road Course | Autocross
Durable enough?
Old Apr 26, 2011 | 10:57 PM
Ryan King's Avatar
Default Durable enough?
Looking for opinions on GM Parts Perf LS3 with hot cam-- http://www.crateenginedepot.com/stor...9-P2218C2.aspx
Will be used in my Griggs Mustang Notchback, weight around 3300 max. I plan to use the car about 40% track, 60% street. I'm concerned about the hyperutectic pistons mostly.
Ryan
Old Apr 27, 2011 | 06:01 AM
FASTFATBOY's Avatar
Ryan
Pistons will be fine, I would be more concerned about the iron block being 50 lbs heavier than a aluminum version.
You have a choice buy the lighter one.
Old Apr 27, 2011 | 11:25 AM
roy's Avatar
roy
Fatboy the LS3 is an alu block.
Old Apr 27, 2011 | 01:36 PM
ZexGX's Avatar
You shouldn't worry about the pistons. As with all LS motors, oil control is key. There are many discussions on this forum regarding accusump, drysump, etc... It would be wise to have a drysump if you can afford it. If not, a properly configured accusump is your best bet.
Yes, it is. http://www.southernperformancesystem...ls376-480.html
Old Apr 27, 2011 | 01:41 PM
ZexGX's Avatar
There is a discussion here where some people had the same concerns:
http://www.pistonheads.co.uk/gassing...d%20what%20LS?
Old Apr 29, 2011 | 08:23 AM
Ryan King's Avatar
Thanks for the advice.
