4th Gen drift build
If I needed to build a drift car again, what I would do would just be :
- remove everything in the car to save weight (same under hood)
- put a Detroit locker in stock rear end
- extend 2 inch the front lower A-arms (cut and weld stock ones)
- shortened stock uprights
- make a good hand brake, which is easier on LS brake than LT as me
- you need to have a good suspension set-up. I now have Koni's + Strano springs. I believe maybe not the best but good enough for the money they cost. KW or good coil-overs are just very expensive.
My friend also use a Nitrous express - 100 shot to help when need. We both use 4.56 rear end ratio (him with a TH400 and me with the T56). I have a 250 shot too but don't use it for drift. I believe the more power is not what you really need
Joe, all you really need to get going is the car with a T56. You wont have a lot of angle, but you can still have a lot of fun. Basic standard mod list for me is;
Eibach pro kit springs, bigger sway bar kit and endlinks, drill a hole in the e brake handle and button so you can pin it open, a good clutch, turn one PS pump, lots and lots of tires
Yes i forgot to tell that the first thing that faild in our both car was the steering pump. We both use turn One pump now
Jenson, i'm not forgetting you with the pic, just the car is not home right now
One question though, would the 3.8 be fine starting out or would the LS1 be ideal?
I believe the car would gain from having the mass re-center in the body, as moving battery inside car and fuel tank at passenger seat place.
What do you think ?
Thats not full lock in that pick sporty. Wheelbase is short, moving the gas tank behind axle, put the radiator where stock gas tank is. Robby just did this with his car. I'll get him to send me some pics.
Then I carefully grinded the steering rack end that connects to the joint.
The last thing was to make extension rods between the rack and the track rod end.
I have not measured the angle and do not have any part numbers for you, sorry.
Here is a video for those who are interested
