4th Gen drift build
If you can adjust the rake of the car towards the front, that can help get some of the weight transfer up front. You can do this with a "weight jacker" setup that fits between the springs and rear end. If you had adjustable shocks, you'd be able to adjust the firmness and in turn can induce over/understeer depending on those settings.
What differential are you running in that 12 bolt?
My 12 bolt have an HD Eaton Posi
Sway bars are Hotchkiss in front and rear (37mm front and 25mm rear) (http://www.summitracing.com/dom/part...t/model/camaro )
I daily drive with larger tyres at rear (275/315), but I use 255/255 for drift events
let me know if those parts can affect this understeering (all parts listed are on the car) :
- LCA relocation brackets + LCA
- adjustable torque arm
- subframe connectors (web style)
- Strano springs
- Bilstein HD shocks
- car has weight reduction : no more heater, A/C, dashboard removed , carbon fiber hood, UMI lower and upper A-arms, ... which are mainly on the front. I believe the rear is heavier with my 12 bolts so it should have changed the gravity center on the car
Also : I have 5° caster ; -2.5° camber ; toe 0
I have an event soon so I'm thinking about getting an airlift 1000 to stiffen rear quickly. a friend of mine has one and it seems to help on his car (which don't have my understeering problem)
Is it all the time? While your on power? E brake? Is it under steering while drifting or grip driving? I think your front end is to tight just by looking at your specs though. I'd disconnect the front sway bar to test theory
- Strano springs
Back when I was an extrovert, 90% of the people with ''understeering cars'' worked great when some simple settings were made to the control panel attached to the steering wheel and pedal box.
Your car is a manual correct?
I will set the pinion angle to 0. It was more. I will also disconnect the front sway bar tomorrow just to see what will change. I believe I should also set the LCA at the stock position (I have relocation brackets).
The problem is the worst when I reduce speed on cornering then put power again : if the car start to go straight instead of keeping the rear end turning, it just change his way and the front start to initiate a straight direction
My car is manual yes
Initiating : depend on the part of the pad / track. For some very short turn parts, you have to use the Ebrake. the short radius is the worst for my car. Others are OK. My friend also use a 4th gen Camaro and no problem with its car. he can turn in very short radius. my car just don't want
If your buddy has no problem in his, I would have him drive yours. You're probably just turning in too much and not letting the front tires track in the direction they're trying to go.
I will also let my friend drive my car so he can give his own opinion.
If you run big sticky tires up front with stock steering angle the car is going to spin at any extreme angle. Traditionally on an actual drift car you'll have a lot of stagger, and a suspension that unloads the inside front tire. By having large amounts of grip in the rear as opposed to the front it allows the car to dangle at the edge of manageable slip angle.
My car I'm going to run 225/255 setup on stock vette wheels, and massage the knuckles to about 50*, fix my diff, add an accusump and proceed to party.
Yup, stock 10 bolt with the AAC cover/girdle, auburn pro diff. and 3.42's. I have H/C though. Robbie swapped to a 4.11 on his stock LS1 and said it really helped.
I was thinking of doing shorter gears and a diff on mine with steering angle just to see how it did. I did some testing in Mexico the other day and my factory diff does not want to play ball when drifting to the right.
They're doing a 'street legal' series here in Texas, it would be hilariously fun to troll the entire fanboy concept by clowning on everyone in a mostly stock 4th gen Camaro, but I'm a little skeptical about breaking rear-ends now.
The 3.42 is fairly strong for what we are doing, these things are like glass with some sticky tires and a dead hook, but all we are doing is spinning. I clutch kicked the clutch out of mine too, rear end is still perfect. And it has seen a good bit of drag radial launches in the past and has about 98K miles on the rear end.
