Anyone had the back end of the car break loose at high speed, unintentionally?
Yes, removing the relocation brackets all together, they do NOT help handling and can induce unwanted oversteer. Ive seen guys say that they "help out of corner grip" but I haven't found that to be true myself, they seem to just want to make the car rotate more.
Do you have aftermarket rear LCAs? You do not want poly bushings on both ends, ideally you would want either rubber or rod ended bushings. Poly can stick and bind which can cause snap oversteer.
Better shocks will go a LONG way in feel, control/handling and predictability. I would highly suggest Koni sports(adjustables) if you want an off the shelf shock with warranty.
Something else you can do that is very very easy but costly is buy a watts link with an adjustable roll center - you can literally dial in rear grip by adjusting the roll center up or down. I guess you could also buy an adjustable roll center mount for the PHB setup as well, but you still have the negative effects of the PHB to deal with.
Earlier up you mentioned 45 in 4th gear isn't that fast which is true. I have the m29 t56 (or maybe m28? Whichever is geared lower) and 4:10 gears so there is still quite a bit of available torque at that gear and speed.
Can you or anyone else recommend some tires that'll actually help me put the power down? This car can't hook at all in 1st gear and my tires aren't dry rotted. I've had this problem since they were brand new. I've ridden in GTOs with 100hp more with 245 series tires that hook no problem. Is it all in the suspension set up, or is it because there is more weight pushing down on the smaller contact patch? I understand there is a trade off between hooking and handling. I can't afford wider wheels but I can afford new tires. This is a play toy and definitely not a daily driver so a really soft tread compound would be an option as well.
Thanks for the reply, this is exactly the advice I'm looking for. I have factory control arms and was about to switch to some tubular to get poly ends, but its good to know that would've been a waste of time and money.
Look at tires in the 200-300 range. For example a nitto nt555 g2 will probably be way stickier than what you have now. Is the gto you are talking about also a 6 speed or an auto? 6 speed cars shock the drivetrain way harder and will break loose easier and autos, all else equal.
Pick up some used C4 Corvette wheels off craig's list. They are everywhere for around $75 each. put some 275/40/17 tires on them and you are good to go. Who knows, you might even find a set with tires already.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
