Road Racing Road Course | Autocross
maximum tire width
Old Feb 2, 2003 | 03:04 PM
lethel1's Avatar
Default maximum tire width
Hey guys I was wondering; what is the widest wheel/tire combo you can put on a late model camaro, without getting tire rub, I want the back wider than the front: also what backspacing I would use? on 17" wheels
<small>[ February 02, 2003, 03:20 PM: Message edited by: lethel1 ]</small>
Old Feb 4, 2003 | 12:20 AM
Judd's Avatar
Default Re: maximum tire width
Without doing a crapload of work, 17x11s on the rear with 315s. The same combo will also work on the front with a little bit of rubbing at full lock. As far as backspaceing goes, I think it was something like 7.25 or so. Better double check that figure as I'm not 100% sure on it.
Old Feb 4, 2003 | 11:45 AM
Louis's Avatar
The norm is an 11" rim, and a 315 tire. For the 18s, a 295 is the biggest we can run before a 335. FWIW, we ran a 325/285 split on my car before Michelin discontinued the 325s. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Feb 6, 2003 | 08:06 AM
CopMagnetLs1's Avatar
Will a 17 x 10" wheel with a 50mm offset work on the front with a 275 / 40 tire?
Thanks, Chris
Old Feb 6, 2003 | 10:50 PM
VipZ28's Avatar
hmmm would you have to do some beating of the inner fender to get a 335 on the back? 295 fits the fronts without rubbing? I'm looking at some 18X10's for the fron and 18X11's for the rear... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Wanna know if I can make them fit very easily...
Old Feb 7, 2003 | 12:51 AM
Judd's Avatar
I'm pretty sure it might take a little more than a "little" hammer work to clear the 335s on the 11 inch wheels. I ran some 335s on a couple of 17x10.5 wheels. Yea, I know the 335s need at least a 11 inch rim. I got em cheap and used them as a Go-No/Go gage before I spent real money on a set of 315s. Anyways, I actually got the 335s to fit with out rubbing except on extremely bad bumps. But I was giving up a .5 inch to 11 inch rims. I think you would have to trim the jounce bumpers, roll the fenders, and you might have to run a set of LCAs that are narrower than the stock ones. I was also not lowered at the time, so that might put a monkey in the wrench for me. I'm pretty sure it can be done, I'm going to try it when I can come up with enough money to buy a couple more 17x10.5s and get the ones I have now widened to 11-11.25 inches. It would take perfect backspacing and offset to work. With 335s there would be no room for error. I wouldn't try it unless you have some time and money to burn. JMO
<small>[ February 07, 2003, 12:54 AM: Message edited by: Judd ]</small>
Old Feb 10, 2003 | 11:44 AM
Fahad's Avatar
The biggest wheel and tire's at the rear 315/17/40
and the front 275/17/40 on the F-bodies.
Old Mar 1, 2003 | 10:47 PM
2001CamaroGuy's Avatar
It depends on how stiff your springs are in the rear. With really stiff suspention, you can get away with wider tires.
Chris
Old Mar 2, 2003 | 12:03 AM
Orange Krush's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by lethel1:
<strong> Hey guys I was wondering; what is the widest wheel/tire combo you can put on a late model camaro, without getting tire rub, I want the back wider than the front: also what backspacing I would use? on 17" wheels </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Lethal I run the 315/35/17 Nitto 555R's and Yokahama AVS's on the rear of my unlowered Z with bumpstop removal only!
The backspacing on my wheels is 7.93 inches with a +50mm offset! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
http://www.afswheels.com/v2/ecommerce/shopexd.asp?id=22
I am buying a used set of Viper rear 335/35/17's in the near future to try out back on my car, I will post up when I get this done!
I have seen the 335/35/17 on the rear of a few cars and it can be done!
<img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
https://ls1tech.com/ubb/ultimatebb.p...c;f=3;t=004494
<small>[ March 04, 2003, 12:37 PM: Message edited by: Orange Krush ]</small>
Old Mar 6, 2003 | 09:22 AM
BillS's Avatar
I run 315's on 17x11's on all 4 wheels for autox no rub with a light denting in at the rear. I run 315's on 17x11's in the rear for street use. 315's on the front ar a bit much for street use as the car follows ruts in the road severely.
