Road Racing Road Course | Autocross
Look at this post
Old Aug 24, 2005 | 09:49 PM
BLK85's Avatar
Default Look at this post
I found this on an Evo board. They are talking about the handleing of the F-bodies. The few Ive been in have handled better than the 1 Evo and various Raliarts.
Old Aug 24, 2005 | 10:34 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Everyone has opinions, you know how it is.
Old Aug 25, 2005 | 06:50 AM
TTSSZ's Avatar
All I know is I have hade experience on the track with stock ss's and stock c5's and zo6's at driving school. My team did the vetts first. Was outrageous - at moroso in fla. Then did the ss's was also grate BUT, coming out of the corners you could feel them pulling for the wall.
(and there was a big smudge mark where a viper hit on the last turn into the straight) Was similar power feel so you kinda felt like you could go as fast as a vett coming out under hard acceleration, but you had to lift a little to let the front end come around where with the vettes it was easer to get on the gas and still steer for the straight. camaros need to loose some weight. I think that’s my next goal to drop some pounds off mine. Just got new rims ant tires, have a 1" drop and some suspension goodies and plenty of power.
Would love to loose 400lbs of the car some how.
found this...
Free stuff....
9...!ABS
21.5!AC compressor
8.5.!AC condenser
....!AC fan motor
13.5!Airbag and bracket, passenger's
4...!Airbag, driver's
....!Air dam
1...!Air filter
5...!Amp, Monsoon
4...!Antenna, bracket, and motor if applicable
....!Ashtray & lighter
....!Blinker switch
2...!Bolt lengths, extra
....!Brake pedal pad
23..!Bumper, front reinforcement and brackets
21..!Bumper, rear reinforcement and brackets
34..!Carpet & Sound deadening
50..!Catback
15..!Cats
9...!Center console
....!Coating, under carpet
4...!Crossmember brace
....!Cruise control
10..!Dash
20..!Door panels
11..!EGR, air pump, & harware
....!Emblems
....!Fan, 1
....!Fan shroud
5...!Floormats
3...!Foglights and brackets
....FRA mod
....!Gas, Extra
2.5.!Glovebox
1...!Grill insert
4...!Hatch cover
2...!Hatch shocks
....!Headlights
....!Headliner
3...!Head unit
....!Head unit/AC console trim piece
8...!Heat sheilding
9...!Heater core
1...!Hood shocks
3...!Horn
3...!Inner fenderwells, plastic
....!Liscense plate brackets
....!Liscense plate(s)
....!Misc. junk in the car like keys, garage remote, change, owner's manual, etc.
1...!Owner's manual
3...!Panels, under steering wheel
5....Panhard rod brace, upper
....!Parking brake
....!Power brake booster
....!Parking brake handle
....!Power seat motor
11..!Power steering pump, pulley, idler pulley
....!Power window motors
1...!Rear view mirror
9...!Seatbelts (rears and passenger's)
34..!Seat, passenger's
19..!Seats, rear
3...!Sheetmetal, extra double walled
....!Shifter ****
5...!Side impact bars
35..!Spare tire and jack
7...!Speaker panels, hatch
5...!Speaker panels, rear passenger's
15..!Speakers
35..!Spoiler (Weight measured on a Pontiac)
....!Spring isolators
2...!Sun visors
14..!Swaybar and brackets, front
....!Taillight(s)
2...!T-Top holders
....!Under car tow points
1...!Washer fluid pump
9...!Windshield washer fluid
2...!Windshield wiper reservoir
3...!Wiper arms
3...!Wiper motor
....!Wiring, Excess
Wallet mods....
3...Airlid, aftermarket
3...Chromoly LCAs
3/9.Carbon fiber driveshaft
14..Chromoly A-arms
30.5Chromoly K-member
....Draglite wheels
....Drag slicks or street slicks
....Drilled axles
24..Dry cell battery
10..Electric water pump
....Fiberglass door skins
30..Fiberglass hood
....Fuel cell
18..'99+ fuel tank for '98 cars
....Headers
....Lexan glass
....Lightweight clothing
35..Lightweight brakes, front
....Lightweight brakes, rear
10..Lightweight flywheel
13..Lightweight springs and shocks
....Lightweight steering column
6...Lightweight steering wheel
10..Manual rack and pinion steering
....Plastic fuel tank, late model
....Powerglide, TH350, or M4 transmission
17/29.Racing seat
....Shortbelt mod
....Skinny front tires
15..Spool
20..TQ converter, small
....Underdrive pulleys
Old Aug 25, 2005 | 07:35 AM
300bhp/ton's Avatar
Didn't read the whole link, but it seemed pretty fair to me.
The Fbody (in fact most American muscle/pony cars) are all over weight with unsophisticated suspension and often antique platforms (Mustang sn95) and often badly setup. Either too soft and wobbly or far too stiff (alla C4 Corvette).
The Evo's are lighter, stiffer with more sophisticated suspension and designed and setup to go round corners rather than 1/4 mile sprints.
The news that the Evo 'handles' better is no more susprising than hearing that Doris Day lost a first fight to Mike Tyson.
All things aside though, the Fbody's handle pretty good, they may not have the most grip. But grip and handling are two different things entirly. And what the Fbody's and Mustang lack in handling refinment they more than make up for with GRUNT and often better styling.
Even supposidly great handling cars like the new BMW M5 can't overcome the excess weight of the car.
If you want real handling then you need to look at cars like these:
With only 260bhp it will keep pace with Formula 3 cars at track days. And a Formula 3 car would wipe the floor with any Evo out there.
Old Aug 25, 2005 | 11:06 AM
JD_AMG's Avatar
Id love for them to see this article:
http://www.roadandtrack.com/article....&page_number=1
Old Aug 25, 2005 | 01:21 PM
Jake19_2's Avatar
How do our cars compare after adding a bigger front sway, koni shocks and subframe connectors?
Old Aug 25, 2005 | 03:28 PM
Cal's Avatar
Cal
My car has that stuff, plus a 300 lb weight reduction and front and rear race wheel alignment. It handles damn good, but still not quite as good as my bro-in-laws Evo, especailly on a bumpy or wet surface. But you more than make up for it on the straights. I outrun an Evo on the freeway three times a couple weeks ago. The first time he topped out at 140 mph, up an incline. I passed him going 150 mph, up the same incline, in 6th gear and still accelerating!
Old Aug 30, 2005 | 11:14 AM
Mojave's Avatar
Subframe connectors dont actually improve handling as they increase the life of the chassis by reducing flex. I had a 92 B4C/1LE Camaro that was driven had by cops, and then auto-xed in F stock for 10 years, and at the corners of the doors, there were cracks starting to form on the roof.
Sticky tires + stock 3rd gen unibody = yeah for cracks!
