What slicks do you like for road racing?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Just like it says. I'm on the last legs of a set of BFG KDs which have been quite nice, but I want a dedicated road course slick. So what do you like and why?
Thanks
BobP
Thanks
BobP
Goodyear Sports Car Specials, 25x13x16, bias ply in 430 compound for road race, 210 compound for autoX. Can't beat 'em. You will need a set of 16x12 wheels to put them on. They will stick so much better than BFG KD's you will be shocked.
Old Drag Racer
Hoosiers 275/40/17's
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
If using Hoosiers for road race, be sure to get the R3S05'S rather than the A3S05 or you will melt the tires. These are both DOT tires; if you can run a non-DOT slick, Hoosier makes a 25x12x16 that is the rough equivalent of the Goodyear slicks in my post above. Hoosier 275/40-17 will be the DOT version, which will not have as much grip as a real slick. The optimum tire size for a car the size of a fbody is bigger than that anyway; you want 315 to 335mm of tread with, or 12 to 13 inches.
Originally Posted by dmtnt
Goodyear G-19 slicks R480 compound. I run 25.5x11.5x18 front, 25.5x12.5x18 rear. You can find them used for ~$70/tire.
and where do you get yours from?
Thanks,
Steve
I ran Michelin Pilot Sport Cup tires this year and for a "streetable" race tire they are good once they get some heat in them. I ran Toyo RA1's last year and liked being able to drive to the track on them.
For 2006 I'm going to run 285/30/18 Hoosiers. I've heard excellent things about them and they are also a very light tire.
-Mark
-Mark
Originally Posted by Steve Rea
How much life is left in these used tires?
Thanks,
Steve
Thanks,
Steve
http://www.jbracingtires.net/
Also Ron Ver Mulm can set you up with the same, only his are more the Hoosiers:
http://rsracing.com/
I get mine from John Berget.
Either place can get them in 16, 17, and 18" wheel sizes, but you are best off with the 16's.
NataSS- I have (6) of the Hoosier RS303 GAC (Grand Am Cup) tires I bought at clearance $140 each. They have one steel belt in them I believe and reportedly last longer than the standard RS303's... who knows. I'm still experimenting with tires and getting my car dialed in.
After I waste this set I plan on running some takeoff slicks. I'm in a TimeTrial Unlimited class and can run whatever we want
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
