is dry sump oil system better than the stock one?
Dry sump is better than the stock setup, but it is not economical. The stock pump is fine for street use and drag racing...it's plenty efficient and reliable. The main reason for a dry sump setup is for road racing. Under high g turns, oil tends to slosh to one side of the pan causing no oil to be pumped to the motor. In a dry sump setup there is ALWAYS a constant flow of oil to the engine no matter what the conditions are. But a good dry sump setup will start at around $3k and goes up to around 5-6k.
