Castor / Camber...how to adjust?
Okay, I have no idea on this. I took my car in to be aligned. They adjusted the toe but told me there's no way to adjust the castor and camber. I know that can't be right. What do I tell these guys?
For auto-x/track use with stock springs (or slight drop springs) max out both caster and camber. Camber will be around -.7 to -1.0, caster between 3.5 and 5.5. Camber is more important than caster, so you want to max it first. For toe, zero toe or slight toe in is good for street driving. For serious auto-x use, up to 1/8" toe out can help turn in.
