Search is down - Torque Arm & Brackets
I finally have enough money to get into some suspension work now
But I do ahve some questions before I buy anything and the search is broke...as usual.
Torque Arms - This car is going to see the twisties, and drag racing as well so im not looknig for a perfect 50/50 mix since I know it can't be done, but a happy medium. I know there is the Tranny mounted version, and the tunnel mount. Which would be best for handeling and some drag racing?
Relocation brackets - Good for road racing or not? I'll be getting LCA's and I know that for drag racing the brackets and arms go hand in hand.
All suspension components will be comming from UMI if that helps yall out some.
Thanks for your help in Advance!
IIRC, drag racers like to lower them as much as possible. For optimum handling, the LCA's need to be level, and allow freedom of movement. Thus, an LCA with a poly bushing at both ends is bad, because poly won't allow the axle to twist when the body rolls. An LCA with dual heim joints or a heim and poly would work much better.
tranny mount it is then, still up in the air on the relocation brackets...
im buying LCA and an adj. PHB soon. the guy from UMI here suggested a race/poly ended LCA for me. ill be doing more autox then drag. i asked about relocation brackets for both, but he hasnt responded yet.
Sam suggested rod ended LCA's and no relocation brackets if running his springs. I have a Spohn TA and works good for Drag racing and Auto X. I wouldn't use this TA for any Road racing as it will give you wheel hop during hard braking in the corners.
