road racers... lets talk about brakes...
Brakes! Ive done searches and read for hours. the general consensus ive gotten is that a fair amount of improvement can be had by upgrading the factory rotors and adding some SS lines with some aggressive brake pads. I wanted to ask you guys to post here and talk about some of the differences youve seen/experienced, on a road course between just upgrading the factory system, and going with an aftermarket brake upgrade. im looking to spend no more than about $2500 on a brake upgrade to give the car a competitive, world class brake setup that can be taken to a track and beat on. im leaning towards a certain upgrade kit that includes rotors, and porsche 996 TT front calipers. opinions? what really works in the real world on the track?
Maintenance costs were 1/4 what the factory or C5 brakes were.
You will NOT be disappointed. And Steve is a great guy to work with.
What turned me off of Willwood or Stoptech was that I was locked into Willwood or Stoptech pads and rotors.
The brakes Steve offers are off the shelf Porsche brakes and easily available from a number of vendors and suppliers.
Now, maybe things have changed ... it would pay dividends to do some homework on consumables.
I've tried a number of different pad compounds on a variety of cars, truly preferring CarboTech (www.CTBrakes.com) for pads. They offer a great street pad (Bobocat) that's not too dusty and a variety of track pads XP series that I run on the track.
Hope this helps!
Feff
Hope this helps!
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Feff
I run P-car products Caliper and rotors on the front and back with Pagid RS44 pads since 2000. I am quite satisfied and a lot of people are amazed with the tremendous braking capability.
so then many people seem to like the P-car conversion- for those of you who have them is there anything above and beyond the kit sold for about 2,000 that you need to give the car track-capable braking? say, a proportioning valve or a change in the rear brake system? ive heard the Stainless steel or braided brake lines are a must...
Brake lines are a good idea along with a really good fluid.
I also had 2 sets of front brake pads ... street and track. I had the best luck with Pagid Black for the track and Porsche street issue pads.
I used the stock brake tune, but had terrible rear wheel hop when I really got on the brakes hard. A prop valve probably isn't a bad idea.
Ill have to check into the p-car factory pads. so far everyone ive ever talked to has had great things to say about the p-car brake kit. anyone know how much/where to get a proportioning valve setup? oh and are the factory rear brakes adequate for hard street use/ occasional road track use?
From my perspective on the rear brakes I didnot have much luck with them for track driving . For autocross no problem, but for hard track driving , the rear pads would wear to fast and smoke irregardless of the different compounds I used.
what do you reccomend for an alternative to the rear brakes? i checked out movit's site and found it hard to navigate...
