Rod Ends On The Street
A quality rod end will be as quiet as a poly bushing.
Get a product called DGF 123 at a NAPA to lubricate the rod end surface.
I ran HErb Adams LCA's and PHB with rod ends on all of the ends for about 3 years on a 3rd gen that I had and they made zero noise. I'm now running BMR LCA's and PHB with rod ends and they have been noisy from the day they were new. THe obvious difference here is the rod ends themselves and it was a big difference. But, they have worked well and I've had no trouble with them at all (even driving in rain and snow)....
GOod luck!!!
The only ball joints I can think of are on the upper and lower A-Arms. Not sure how a heim joint would apply ...
It could be done. However, the tie rod ends really don't see that much force applied.
The primary purpose behind a heim joint on the rear is to allow the diff to articulate without bind.
I was looking at refining the suspension, and figured that I might investigate the idea.I would like for the car to have some more negative camber, for better handling, since it sits the way it came out of the factory.
For more, you'd have to either go with aftermarket A-Arms or slot the lowr A-Arm mounts. that could give you another -0.5 degrees I would guess.
You need to come and join us at road courses. We are going to TWS this weekend and Hallett (near Tulsa) in Septemeber and Motorsport Ranch in Cresson in November.
www.thedriversedge.net
TWS is Texas World Speedway. A few of us from the area are going down there this weekend.
I have a 2002 1LE, and also live in Mansfield.
BTW, LG motorsports was super helpful (on a saturday afternoon) in helping to answer my install questions on the brackets. THANKS GUYS!! FYI....installing the brackets isn't quite as easy as you think it'd be, but it still wasn't bad.
Anywho, back to the question....I have to put some miles on them, but so far the rod ends seen like the way to go!
brandon
