Soft brakes
Also, I have bled the entire system and went back and flushed the system after the bleeding didn't work. I'm using Super blue fluid if that has any effect on any advice you could give me.
What should I check next?
Thanks,
William
As far as the vibration, rotors seem like a good place to start. Part store cheapies work just fine, and you will need them eventually if you start running real pads.
Also, HP+ aren't really up to serious HPDE abuse. I would consider switching to a real pad like a Hawk HT10, HT14, DTC70, or a Carbotech XP10 or XP12 for the front, while leaving less aggressive pads in the rear to avoid axle hop under braking.
1) If you plan on using these pads a while longer for street use, bed them in again. Do several hard stops from 60-80mph to a crawl, over and over, about half a dozen times. This should clean the rotors and unglaze the pads somewhat.
or
2) You can change up to a race compound and do the same process if you plan to keep race pads on instead. The race pad will likely clean the rotors even better.
or
3) You can have a shop turn the rotors, but you will lose precious rotor thickness in the process.
The HP Plus does fine for track days on lighter cars (like my RX-8), but it's not enough pad for a Camaro. The pads Mojave mentioned are all great choices.
I was hoping the HP+ would do for a street/track pad since I didn't want to have to run a dedicated track pad but I will now consider replacing them for track duty with a more aggressive pad. Lighter pads will definitely be left on the rear as I already am having bad axle hop under braking. If i can get the car to have at least a consistent pedal then I will go about bedding in the brakes again. As it is, it's hard to make a hard stop period much less one from speed.
Thanks for the advice so far guys
I'm very new at this but enjoying every bit of this racing that requires steering input as opposed to my roots with straight line racing
William
Thanks,
William
Thanks,
William
William
either way, from what ive heard, brake ducts are almost mandatory for even just a track day. you can do it without, but with ducts it will greatly increase your rotor and pad life, not to mention cool them enough for proper braking. you may think youre not getting into the brake very hard, but keep in mind youve got almost 2 tons of weight coming down from what, 40, 60, 80, maybe faster? plus the repeated use of brakes on a course as apposed to occasional use on the street wont allow them to properly cool. im working on my own ducting now, just in case i ever finally get to a track for some regular fun runs...no racing or whatever.
http://www.cobaltfriction.com/compounds/
Even better would be the XR3 pad listed (it would need to be swapped out for street use however).
Again, HP Plus will definately be overwhelmed by the F-bod with any decent lap pace.
I had good luck with Porterfield R4s at TWS. they are very grippy when warm. It would be wise to use better than average brake fluid too. something like ATE Superblue.
Disclaimer: I don't sell any of these products; just relating my experiences with them.
Thanks for the tips guys!
William
