TurboCharged Auto X guys
Looks like I will be putting a turbo set up on my SS, but want to start doing Auto X and some track days. I drove a turbo set up in another fbody which might be the way I go, but not sure if it's going to be good for autox. The boost kicks in full around 2800rpm. Your experienced input please.
While you can certainly auto-x a turbo f-body, you really don't need the extra power. Even a stock LS1 has more than enough power for auto-x, even on big R's. As far as 'good for auto-x', I'm not sure it will actually make your car any faster, but it will make things interesting.
As far as track days: cooling, cooling, cooling, and more cooling. With boost, you are going to be making tons of heat. You will need a big oil cooler at a minimum, and probably a bigger radiator as well.
