Anyone have the JPR cam tool I can rent?
Old Mar 16, 2006 | 03:10 PM
HOSS's Avatar
Default Anyone have the JPR cam tool I can rent?
Like it says. Thunder is out of them, and haven't got a shipment in for a while. I was wondering if someone would let me rent one. I would pay shipping both ways too of course. Thanks.
Old Mar 16, 2006 | 03:58 PM
vettenuts's Avatar
Go to home depot, pick up some 5/16 rod. I made mine.
Attached Thumbnails Anyone have the JPR cam tool I can rent?-lifter_tool_1_2.jpg   Anyone have the JPR cam tool I can rent?-lifter_tool_2_2.jpg
Old Mar 16, 2006 | 03:59 PM
Ωmega's Avatar
Don't waste your money. Go to Home Depot and get a 5/16" dowel rod. I've used them on every cam swap, and have never looked back.
Ωmega's Avatar
Damn, too slow
Old Mar 16, 2006 | 04:02 PM
vettenuts's Avatar
Only by a minute
Old Mar 16, 2006 | 04:17 PM
Joel_SS's Avatar
So does the rod need to be approx 20 inches? Does it have to have the bends at the end?
RyRy's Avatar
I think it should be 22" and its very easy to sand down the end a little
Old Mar 16, 2006 | 04:22 PM
Ωmega's Avatar
Nah, you don't need the bends in them. It makes it a little easier to turn them as you push them into the block.
Old Mar 16, 2006 | 04:33 PM
HOSS's Avatar
how much do i sand them down?
Old Mar 16, 2006 | 04:37 PM
Ωmega's Avatar
Just sand the tips down a little so theyre rounded.
Old Mar 16, 2006 | 04:42 PM
HOSS's Avatar
thanks a ton guys, I appreciate it
Old Mar 16, 2006 | 05:55 PM
blkbird's Avatar
Good info....
Old Mar 16, 2006 | 06:10 PM
BTLFEDSS's Avatar
Same here then you have them if you ever need them again
BTLFEDSS
Old Mar 16, 2006 | 08:50 PM
ROCNDAV's Avatar
Do you leave them round, or do flats have to be machine/ground along the edge to hold the lifter up?
Old Mar 16, 2006 | 08:56 PM
Ωmega's Avatar
I left them round.
Old Mar 16, 2006 | 09:03 PM
theinstag8r's Avatar
i had to grind a very slight flat edge to get mine in
Old Mar 16, 2006 | 10:04 PM
Xtnct00WS6's Avatar
I sanded mine down like the pics above, but it didn't seem like I needed to. Try using the rods w/o sanding them down and see if it works. You might be able to save some time.
Old Mar 17, 2006 | 12:00 AM
Michael55123's Avatar
No need to sand them down. Lifter can't go through the tool. It's simply not possible. Just slide them in, make sure they're all the way back, and don't look back.
Old Mar 17, 2006 | 12:48 AM
ChaseSS's Avatar
i have the in car valve spring compressor tool... pm me on how you want to rent it
EDIT: i also have the magnet tool that prevents the lifters from falling down too
