Ok found one car on boosted list with fast 90 tb anymore dyno numbers.
Anyone running a fast 90/90 setup with a blower or turbo. I have seen that one on the boosted list and it said like 800rwhp I think it was..some lingenfelter engine or something.
There has to be a few more of you 90/90 guys on turbos or blowers.
Or does everyone sell off their 90/90s and go for a ls6 intake and reg tb?
I wanted it for a couple reasons.One was the direct port nitrous and burst panel for nitrous options.The other was figured while peak power might not be much higher from some dyno tests area under the curve might be better and it might make a diff at huge power levels on a big 400 plus motor.
Gmr customer was going to use one but now switched at last minute.Too bad didn't get dyno of the fast 90 and his newest manifold..
Direct port is just another intimidation /car show type mod but small shots of spray do work well with turbos also. I doubt would ever go past 100 shot.
I will be happy with the fast as long as it don't blow apart and since some boosted cars have run it ,don't think it could be that bad. I would email that address you gave me Pro Stock but not sure they would talk to me being didn't buy the fast from them.
Also while the peak power was no better in most dynos on the fast 90 maybe the area under the curve or other things was better?
I would still think a fast 90/90 type setup would outperform the ls6 or ls1 intakes and small tbs.
In my dsm upgrading the intake and tb seems to help quite a bit for power,especially in the upper rpm ranges.
BOSS APPROVED!
