- Camaro and Firebird: Transmission Cooler Information
Important information to help you understand your Camaro or Firebird
Browse all: Tranmission Guides
Everything you need to know about tranny coolers (4l60E F-Body)
, so it'll take me a little while. Thanks for the input Tube and fin flow better, but tranny coolers arent put on the increase flow
...The only time you need to worry about the stacked plate being a restriction is if you plan on running more than 1 cooler in the same tranny line. You shouldn't need more than one cooler in most cases.
Personally, I think that stacking coolers is excessive. If anything just run the 70264. I have used this one multiple times, and have had good luck.
Although the T&F might not be as efficient, mounted this way it is in completely open air and not backed up against a hot condenser/radiator. It gets all the airflow routed to the radiator but not the extra heat. For that reason, it is probably more efficient. Here's a pic from that thread:
http://www.bmracing.com/PRODUCTS/Universal-SuperCoolers
Or if you like you can go to Thunder Racing to purchase it. Really fast shipping!!
http://www.thunderracing.com/shop-by...olers_116.html
I personally run a good sized tube and fin cooler (bypassed stocker), mounted in front of the condenser. I hardly ever use my A/C, so added heat from the condenser isnt too much of a concern. My next mod is to add in a trans temp guage.
I'm trying to decide what size and brand, I'm looking at the Hayden 26,000 gvw transmission cooler but I don't know if it will fit infront of the radiator. Does anyone know?
Also are the fittings for the connections 3/8ths?
Anyone with any info I would greatly appreciate the help I'm new to this stuff and doing want to make a n00b/rice mistake.
