243 heads that were milled to 53cc
Old Oct 15, 2012 | 09:54 PM
daturbosix's Avatar
Restricted User
Default 243 heads that were milled to 53cc
looking at picking up a engine.. and the guy said the heads are milled to 53cc chambers.
so how much was it milled, about?
what does that do to my valve geometry?
what length pushrods do i need?
rockers?
ps, motor is complete minus pushrods and rockers... thats where this guys build came to a stop.
Old Oct 15, 2012 | 10:32 PM
Grr's Avatar
Grr
depending on what gasket, they are milled around .085-.90,
with a .040 gasket depending on the cam 7.320 or so. need more info.
Old Oct 15, 2012 | 10:34 PM
daturbosix's Avatar
Restricted User
edit: heres all the details i have at this time
383 short block K1 rotating assembly.
K1 crank 4.000 4340 crank.
K1 6.125 Forged H beams
Wiseco -32cc forged pistons.
Comp cam hydro roller lifters
With 64cc head motor would be 9.4-9.5 or so on comp ratio
LS6 243 Ported heads
New valve job.
Titanium retainers
Milled to a 53cc
2.055/1.6 stainless valves.
Manley valve springs good to .650
631/631 240/244 lobe center 111
Old Oct 15, 2012 | 11:00 PM
garygnu's Avatar
those valves will be close to the cylinder walls.
Old Oct 15, 2012 | 11:09 PM
Grr's Avatar
Grr
that is an absolutely terrible setup, sorry but its not gonna make near the power it should. Why the huge dished piston then small chamber heads?? compression with those heads on it will be 9.4 unless you have a typo with the piston dish.
valves are gonna be shrouded to death
and that cam is entirely too big for that setup
Old Oct 15, 2012 | 11:17 PM
daturbosix's Avatar
Restricted User
i believe it was suppose to be a boost motor, although i didnt want to run boost. i was just gonna toss it in a car and drive it the way it is.
but, that being said.. what changes should i make to make it the way it should be? set of pistons? different set of heads?
Old Oct 16, 2012 | 06:21 AM
Grr's Avatar
Grr
well it will work to drive NA, I would definately go with a smaller cam though 23x/24x .600, otherwise its not gonna make anything down low. just dont expect to make huge power with it. Not to mention anything over .600 lift there is no way you will have enough piston to valve clearance
Old Oct 16, 2012 | 08:04 AM
velox65's Avatar
Unless you got a killer deal I'd pass on it, seems like a mismatched combo to me.
